Fuel pump door
Finally replaced my sunken brass float and installed the fuel door , followed Steave83 thread , TR |
Are those wire nicked up a little?
Looks good btw! |
I have to do the same job too, and I was thinking about cutting the floor.
Is there a thread somewhere that I can get some measurements? |
No the wires were penetrated for testing ,Steve83 super motors has a good write up on this door Good luck TR .1983 Ford Bronco Bronco Fuel Pump Access Hole pictures, videos, and sounds | SuperMotors.net |
Solo motorsports has a plate to use over cutout with instructions where to cut.
https://www.solomotorsports.com/shop...-access-cover/ |
Good info, I ordered metal off eBay , 29.50 plus 18.00 to ship .This mod will save anyone a headache dropping the tank.My 85 f150,was removed to install bushings and boy was it a pita .Goodluck TR |
Originally Posted by th67ss
(Post 18410156)
Looks good btw!
Originally Posted by Black Ford XLT
(Post 18412089)
No the wires were penetrated for testing ,Steve83 super motors has a good write up on this door Good luck TR .1983 Ford Bronco Bronco Fuel Pump Access Hole pictures, videos, and sounds | SuperMotors.net I dont understand guys that cut a hole in the floor of their truck for access to the fuel pump especially on an enclosed vehicle like a Bronco. Guys on another forum do the same thing. Drop the gas tank. It isn’t that difficult and how often do you have to do it? Maybe once or twice in the life of the truck? Make sure you seal it up so fumes don’t get in |
Wires were sealed -no photo-I have changed the fuel pump twice -1996 and 2012 and fixed the float twice. That's a total of 4 times Already!. My 85 F150, the tank (16.5 gallon) has been dropped 3 times ,for float issues.(NO in the tank fuel pump) The Older you get being under a vehicle isn't Fun Good luck TR
Eight years ago I replaced both tanks in my F-150 because it had been sitting for 8-9 years. What was in there was no longer fuel. Haven’t been back since. I think I had to drop the tank in my ‘87 Bronco once or twice in the 20 years I’ve had it. Maybe I’ve just had better luck. |
(Post 18414483)
Eight years ago I replaced both tanks in my F-150 because it had been sitting for 8-9 years. What was in there was no longer fuel. Haven’t been back since. I think I had to drop the tank in my ‘87 Bronco once or twice in the 20 years I’ve had it. Maybe I’ve just had better luck. I have to get some steel plate to remount a gas can (I plan to use the Rotopax mount and fuel can) that I have mounted on the spare tire carrier. I just might get a piece big enough to make a floor door and mounting location. I am really considering cutting the floor. |
