Cold Weather Idle Whine 6.7L
Hi all,
Looking to see if anyone else with a 2017+ 6.7L PSD has had a cold weather whine/squeal at idle or high idle (750+ Rpm)? I have attached a video below showing a it. It seems to happen when weather is cold out (-5f to -15f that is was today). The truck is always parked in a heated garage at night, and it does not make the noise when I first take it out, but after it has been outside for a while (whether or not it has running and driving the entire time) the noise eventually starts when it's this cold. I just had it into Ford today, but they were unable to figure anything, and it goes back in tomorrow. I am just looking if anyone else had any insight I could possibly give them. Thanks in advance! Video below. Whining Uncles Non-whining 6.7L for reference: |
Yup, I've had that. Almost seems like the belt is loose. But, once it warms a little, it goes away.
Originally Posted by danr1707
(Post 18407184)
Mine does it also but only below 15 degrees or so. I thought maybe it was the engine calling for def. Because I've heard def freezes around that temp. It only does it for a few seconds on mine at first start up. I first experienced it while hunting and the temps were below 0. As I ran to the truck thinking there was something wrong, like maybe gelled fuel it stopped by the time I got there. I've probably experienced it 4-6 times in the last month or so. It doesn't happen every time or since the bad cold front has left.
Well just got the truck back from the dealer the second time, and all seems to be fixed. They replaced the belt and fan clutch, and when I picked the truck up it seemed to be cold enough outside, and no noise was to be heard.
Apparently on 2011-2016 6.7Ls the fan clutch was a known issue, but they were supposed to have been updated for 2017+, maybe I just got leftover parts lol. Anyways we will have to see on the next extremely cold day, and if it's gone then I will be able to rest easy. |
Originally Posted by joshjohnson93
(Post 18406926)
Hi all,
Looking to see if anyone else with a 2017+ 6.7L PSD has had a cold weather whine/squeal at idle or high idle (750+ Rpm)? I have attached a video below showing a it. It seems to happen when weather is cold out (-5f to -15f that is was today). The truck is always parked in a heated garage at night, and it does not make the noise when I first take it out, but after it has been outside for a while (whether or not it has running and driving the entire time) the noise eventually starts when it's this cold. I just had it into Ford today, but they were unable to figure anything, and it goes back in tomorrow. I am just looking if anyone else had any insight I could possibly give them. Thanks in advance! Video below. Whining https://youtu.be/uboUvro0f6Q Uncles Non-whining 6.7L for reference: https://youtu.be/o8PAXfllLiA |
Yikes..... take it in |
(Post 18411183)
Originally Posted by Truckie256
(Post 18411537)
Kinda sounds like the beginnings of my noise.... 2017 250 6.2L.... ended up being a Fan Clutch... said it was running full on all the time. only when cold starts (40F) and below
https://www.youtube.com/watch?v=CpkePCp0fE4&t=62s
Originally Posted by Imadentguy
(Post 18411546)
