Between Stinky's legs, there's a...
...spare tire that's old, crusty, and doesn't match the size of my new tires. Yeah... I have a spare tire and old crusty parts that are mismatched, but this isn't about me.
So... I need a rim and a 33" tire that will be a full-sized spare, but it's not going to be in the rotation. I currently have a steel rim, but the crap they put on the roads puts me in a position to drop it and maintain it if I go steel again. Do they make powder coat or galv rims like they do for trailers? Should I go aluminum? What do you guys in the salt belt do? Do you recommend an inexpensive 33" tire that's good enough to get me to the tire store or home while towing? |
Here's a good site to browse. There aren't too many 33" tall tires for 16" rims, so your stock spare wheel will most likely have to go. I've had steel spares under the beds on all my trucks, and they've all been badly rusted when I got them. Not sure I'd put aluminum under there though, as every aluminum wheel I ever had has gone flat just sitting unused in the garage. I don't rotate my spare, the best old tire becomes the spare when I get new tires. I've wire wheeled and primed and painted the steel, and put many coats on it before mounting the spare. The tire itself is cleaned with armor-all, and sprayed again before going under the truck. All that said, I hadn't used a spare in decades, until last month when the 17k mile Kuhmo tires on my car started slipping belts.
You could have the current rim sand blasted and then take somewhere and have it galvanized. I know there’s places that will dip it. Not sure on cost. |
Rich, I just threw my best 265/75-16 on the OEM aluminum rim up there.
You can get it powder coated but having one wheel done won't be cheap. Not that getting 10 done would be cheap either but the cost per wheel...well you know how it goes.
I know it’s a pain but rotating in the full size spare is nice on the wallet for some extra miles per set loved it about my Jeep and laughed at all the brand new dry rotted spares down here. My truck came w a lfull size spare”until it was time to use it and it was a Chevy bolt pattern...ended up buying a 33 inch tire/rim from a 2011 I believe. I paid 50 bucks and it’s a Ford made chrome wheel there was some talk it may not fit and I would further research the bolt pattern size however you may be able to fit a far newer wheel for cheap and since it’s a dedicated spare and matching is not important. Also had the same tire fall out on a brick road!! Amabualnce was behind me and lit it up good to have a pro behind when something goes wrong. It would be good to inspect the tire carrrier. When I get to it I’m going to buy a new one or put in some stainless marine grade 8k line on the old one. Then I’ll have a 33 to put on the front of the truck and keep 35’s on the rear until I can get to help. (That way the rear end stays matched) On longer hauls I bring a 35 mounted on my old wheel for a full size spare. |
Could you Plasti-Dip the steel enough to protect it from the elements?
Originally Posted by ZachinCO
(Post 18369460)
You can easily fit a 285-75-16 but it will be really close to the exhaust, you could probably wrap the exhaust. As for the wheel sand blast it and repaint it, Harbor freight has a very compact sand blaster that works great.
I'm looking at a LT255/85R16
I have never once used a spare tire on any of my trucks, because I keep the tires in top condition. This spare is there for just in case... so the smaller and cheaper, the better. If my tires were 32", I found some that would fit a 16" rim for $100... but 33" tires double in price, even on the bigger rims. I will review the steel rim, and see if I can prep it for bed liner. Then I think I'll go into the wayback machine and buy some balloon tires for the rim. This is not a firm decision - it is my initial thought after the bed liner trigger. Thanks ZachinCO. |
Originally Posted by Tugly
(Post 18369641)
I try to match the tire and wheel size (don't care about wheel style just size). I bought 5 new tires at my last purchase, and plan to replace with the same, and maybe even put the spare into the rotation and remount a new one in it's place. I run KO2s which wear out fast, however. It's not like the spare will be under the truck for 10 years or even 5. More like 1-2.
(Post 18369300)
I bought my truck from a truck and SUV "superstore" in my area (no dealership was going to put a 4 year old truck on their lot with 146K miles on the odometer). When checking out the truck I kicked the bald spare tire and there was a dull thud...it was flat. One of the contingency items for the purchase was a name-brand spare with at least 1/2 tread on it. Since it was a "superstore" they installed a lot of lifts in-house to pull the kids in off the street and overcharge them for all the goodies (the one I bought hadn't been done yet and was bone stock...one of the reasons I was interested). To keep things easy for them they took one of the Lariat wheels they already had sitting in the back (with a tire on it) and gave it to me as my spare.
Originally Posted by RigCity
(Post 18369454)
Just my .02 |
Originally Posted by brian42
(Post 18370010)
I tried that with my last two sets of tires. Both ended poorly for me (both were tread separations...only one of them was caught before the tire came apart). Whether it was me rotating all 5 tires or not I will never know but it is a strange coincidence that the only two times I've had this problem is the only two times I've ever done this. Personally, I will never do it again. I have a brand new tire under my truck's butt only to be used when needed...then it goes back. Every time I buy new tires I will buy a 5th for the spare if the spare is over 6 years old.
(Post 18369641)
I have never once used a spare tire on any of my trucks, because I keep the tires in top condition. This spare is there for just in case... so the smaller and cheaper, the better. If my tires were 32", I found some that would fit a 16" rim for $100... but 33" tires double in price, even on the bigger rims. I will review the steel rim, and see if I can prep it for bed liner. Then I think I'll go into the way back machine and buy some balloon tires for the rim. This is not a firm decision - it is my initial thought after the bed liner trigger. Thanks ZachinCO. Did Ford ever put 18" steel spares under the leaf sprung Lariats / Excursions that came with 18" aluminum wheels? If you had such a wheel you could rotate in your old tires as time went by. Even if you went new, not sure that replacing every 6 years is needed as they would never see sunlight (UV) and if you took them out every now and then and cleaned them with a good tire preservative they shouldn't rot. If you're so worried about wheel rust / tire rot; then you should be pulling the spare out from under the truck once a year anyway - probably in spring - and repairing any rust and inspecting the rubber, and just making sure the spare hanger mechanism is working. The only problem with "smaller and cheaper" is that should you need it with a heavy load it could be greatly overloaded, or if it's a different wheel diameter, it might behave differently at higher speeds and greatly affect your travel time back to home or repair. |
Put a thick coat of fluid film on both sides every fall |
