Connect WAZE by Bluetooth?
I would like to connect my android Pixel phone 2 to our 2019 Lariat by Bluetooth. I have found numerous references for doing it by USB but none by Bluetooth. The manual in this regard is vague and without details. Is this possible?
Thanks Bill |
I don't think you can connect with Bluetooth for WAZE you have to use USB , Bluetooth is mostly for the phone functions and USB for the rest
If you have an Iphone just plug it in and it will come up automatically. Only down side is you will only see the Iphone apps, not all of them but a few, and you can't go back to the other screens unless you unplug. Or at least I haven't figured out how to do it with out disconnecting.
You have to plug it in for video transmission. Only audio can go over Bluetooth.
Good thing with Android auto is you can easily switch back and forth between sync and your apps, unlike iOS. |
Originally Posted by BillRes2
(Post 18362580)
Thanks Bill |
AndroidAuto and Apple CarPlay require a cable in any car to run. The quantity of bandwidth needed to drive a display from the phone isn't possible over current Bluetooth. Google did release a version of Android Auto in 2018 that will work over wifi but very few manufacturers support it - think years out.
In short - think Bluetooth for cell phone calls, texts and streamed media to Ford Sync 3 standard screens. You have to connect a cable in the USB ports under the screen for Apple CarPlay or Android Auto to work. Like in most cars, you can play the audio output of almost any phone app over Bluetooth. For the truck, just turn on the Ford Sync 3 audio and set your phone as the source (assuming it's paired at this point). This has nothing to do with Waze but will of course work for audio directions if that's what you want. Hopefully that covers all angles in one post. |
Originally Posted by Tricon
(Post 18362792)
Originally Posted by JeepPuller
(Post 18363760)
I'm pretty sure I was able to switch back to Sync from Apple CarPlay. I'll check later today to confirm.
(Post 18363760)
(Post 18362580)
Thanks Bill On my WAZE (on an iPhone) there is a setting (in WAZE - NOT Sycn3) under the Advanced setting in the app to "Play as bluetooth phone call". That way I get to play my Sirius/XM via Ford's stock system, get WAZE updates via the Ford speakers (via Bluetooth to Sync3), and get phone calls via Sync3. I don't use a cable. I don't want Car Play. btw.... You can do the same with Google Maps. At least in IOS.... Go to settings, Navigation and set "Play as Bluetooth phone call". You will notice on the Sync3 screen that it looks like a phone call coming in when WAZE (or Google Maps) makes an announcement, but I hardly notice that and it only lasts the duration of the announcement. Problem solved?? |
Waze over Bluetooth is only an iPhone option. Not android. Sorry.
Originally Posted by briangp
(Post 18364592)
Anyone can hear Waze on their stereo over Bluetooth, that's been around for a decade or so... Nothing special there. It works on Android, iOS, blackberry, basically any phone out there. |
(Post 18364599)
You can see your Waze screen on the Sync 8" monitor, over Bluetooth? Sorry, that's just not physically possible.
Is it maybe that to hear WAZE from an Android phone the phone has to be connected via Bluetooth as the Sync source thus rendering other audio sources unavailable (like Sirius/XM, Radio, etc.)?
Is that maybe why I set up WAZE to connect as a bluetooth phone call (thus only interrupting the selected audio source like Sirius/XM or the radio)? honestly - I don't remember. But I know that until I found the 'connect as bluetooth phone call' I didn't like my choices. |
Originally Posted by rashers
(Post 18363218)
In short - think Bluetooth for cell phone calls, texts and streamed media to Ford Sync 3 standard screens. You have to connect a cable in the USB ports under the screen for Apple CarPlay or Android Auto to work. Like in most cars, you can play the audio output of almost any phone app over Bluetooth. For the truck, just turn on the Ford Sync 3 audio and set your phone as the source (assuming it's paired at this point). This has nothing to do with Waze but will of course work for audio directions if that's what you want. Hopefully that covers all angles in one post. regards Bill |
