Ford Truck Enthusiasts Forums
-   6.7L Power Stroke Diesel (https://www.ford-trucks.com/forums/forum205/)
-   -   2013 F350 no high beams (https://www.ford-trucks.com/forums/1564222-2013-f350-no-high-beams.html)
ChrisSpanos 12-01-2018 08:42 PM
I have an 2013 F350. When I select high beams, my low beams go out and I have no high Beams. The high beam indicator illuminates when I select high beams
HDSlowride 12-01-2018 08:52 PM
I'll go out on a limb and just suggest you need two new headlights.
displacement4me 12-01-2018 08:58 PM
Check fuse #39 in the passenger compartment fuse block.
ChrisSpanos 12-01-2018 08:58 PM
That is what I was hoping. Fuses are good, all other systems working normally. I find it odd that both high beams would fail at the same time.. Going to try the bulbs tomorrow, ford did not make the bulb replacement easy
ChrisSpanos 12-01-2018 08:59 PM
That was the first thing that I checked, fuse is good
ChrisSpanos 12-01-2018 09:17 PM
thank you for the responses. I will try the bulb replacement and post an update.
cangim 12-02-2018 08:03 AM
Do you mainly use high beams or flash a lot with them? This seems odd to me as well.
ChrisSpanos 12-02-2018 08:04 AM
I use high beams alot. we live in a rural county and the roads are very dark.
cangim 12-02-2018 08:10 AM
This thread has quite a bit of learning in it as well.
https://www.ford-trucks.com/forums/1...-upgrades.html
ChrisSpanos 12-02-2018 10:59 AM
Good News, both lamps had the high beam filament blown. It took around 45 minutes total to replace both bulbs, the removal of the grill and head lamps was simple; Again, Thanks everyone for your responses. I used The Sylvania H13 Silver Star Ultra Halogen Headlight bulbs, $51.00 for 2 bulbs.
