Ford Truck Enthusiasts Forums
-   1948 - 1956 F1, F100 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum41/)
-   -   MAR-K 25% off on Tailgates (https://www.ford-trucks.com/forums/1562593-mar-k-25-off-on-tailgates.html)
bjmayberry2 11-17-2018 09:32 AM
Got this this morning!
https://cimg7.ibsrv.net/gimg/www.for...2f7d667a8.jpeg
Save 25% On ALL Tailgates
Hurry, 4 Days Only!
Dozens of options to choose from including:
  • All New Push Button Tailgates- A huge hit at SEMA this year
  • Hidden Latch & Link Tailgates
  • Chevy, GMC, Ford And Dodge Scripted Tailgates
Don't miss out on our biggest sale ever!
Use Coupon Code: TG25
Offer Expires 11/20/18
1954wrecker 11-17-2018 12:44 PM
Any idea if they run a deal on bed wood?
abe 11-17-2018 08:14 PM
Give them a call.
But, Chris, if you or someone you know has a router and a table saw you can make your own boards quite cheaply.
How will you finish your boards? Let me recommend that for your truck with patina, you paint your boards. If you paint them you don't need to buy expensive red oak.
hulleywoodworking 11-17-2018 08:52 PM
I've got a full set of the red oak from Mid Fifty that I'm not going to use on my 51 F1. I'll sell it to you real cheap. PM me if you are interested.
John
1954wrecker 11-17-2018 09:07 PM
Originally Posted by abe (Post 18312459)
Give them a call.
Hi Abe, I was leaning towards making my own boards, most of the F250 kits are close to $500 and another $100 to ship....I’m not certain on the finish but I might use a really dark almost black stain or paint them as you suggested. If I use paint, what’s the recommended wood? Also, why do you need a router? I have one, but I planed I’m doing all of the cuts on a table saw unless I’m missing something.
Chris
1954wrecker 11-17-2018 09:08 PM
John
Thanks John. I would be very interested but I have a F250.
52 Merc 11-17-2018 10:19 PM
Chris
The boards have a rabbit on the edges for the metal strips to fit into. You could make them with a router or I suppose a dado blade on the table saw could work, too..
https://i.ebayimg.com/images/g/NOgAA...0Wn/s-l300.jpg
abe 11-17-2018 10:40 PM
Chris
Trucks came from .the factory with bed wood painted the body color, but for your truck I was thinking a black bed. I'm glad you think that too.
If painted, what kind of wood? I'll defer to guys that have more knowledge about wood. I bought and made my own wood (with help from a wood working friend) from red oak bought locally in 1999. When I painted my truck again in 2016 I used oil based paint tinted to match my Meadow Green to paint the red oak after I sanded the spar varnish off. Two boards were checked and split at the end. I replaced them with 1x6 treated boards from Lowe's. The original boards were Northern Yellow Pine grown in Ford's forests in northern Michigan. Modern pressure treated lumber is Southern Yellow Pine.
1954wrecker 11-18-2018 06:48 AM
Thanks, I was thinking about using a dado blade. Using a router over a 8 foot run seems long but I don’t do much with wood.
Abe, what did you use?
Chris
abe 11-18-2018 07:44 AM
I took my boards to a woodworker friend. He has everything a guy would need. We used a router table. BTW, have you seen the page that show the exact measurements for the boards?
1954wrecker 11-18-2018 08:54 AM
Only for a F100, do you have a source for the 250/350?
abe 11-18-2018 09:37 AM
Hmmm, good point. Start a new thread about the F250 boards and someone can help you out.
Brooksy1968 11-19-2018 04:37 AM
board measurements
Hi abe , any chance you could point me in the direction of that page about board measurements for f100's. Cheers.
GLR 11-19-2018 06:43 AM
White oak works well if the truck will be outside. It's used a lot for docks in NY. A guy I know also swears that black locust is better than any P treated stuff.
bjmayberry2 11-19-2018 06:50 AM
I’m not a wood aficionados but I had a guy tell me red oak is bad for a truck bed because it absorbs water? If it’s not going to be outside then maybe it won’t matter.
