2015 Battery life
Mine died today after 3 years and left me looking for a jump
Its sad,nothing lasts like the old days,5 years was the standard I am used too.. |
My OEM only lasted 2 years. I have one year on it’s replacement. We’ll see how long it lasts. |
I believe in general it's partly the anti-theft modules, clocks, stereos, remote start and other gee-gaws and black boxes that tend to run for quite a while after shutdown, sometimes as much as a half hour or more. There are a ****-ton of accessories and power robbing devices these days that draw a very slight current. This is now considered "normal." The battery is probably always slightly discharged/undercharged. Not in a major way but it's enough, causing sulfation the #1 battery killer. In the really "old days" batteries probably had a 1 year warranty or so at best and needed watering several times a year. Maintenance-free batteries changed all that. But in those days when you shut off the truck, the amp draw was Zero. Could come back 6 months later and it would at least start. Not anymore. High underhood temperatures also contribute, engine bays are packed today with barely any room. Charge up the battery to 100%, and esp. if the truck isn't used for a few days, check the voltage at the posts, it will be noticeably down from 100% I bet. A tenth or two of a volt doesn't sound like much but as a percentage of battery charge it is a lot. If you want them to last in modern cars and trucks they will need some attention with outboard chargers & maintainers. No way around it. Or be prepared to swap them out on a regular basis. |
Originally Posted by Excelerater
(Post 18309566)
Its sad,nothing lasts like the old days,5 years was the standard I am used too.. Part# NSBG650001 |
I've never had a new Ford where the battery lasted more than 3 years. My daughter's 2015 Fusion just needed a new battery, less than 30K miles on the clock.
I've purchased only MC Maxx batteries, they have a 99 month warranty and that pretty much beats the industry. |
I agree with Tedster. There are a ton of parasitic loads on the battery these days, and if your driving habits are relatively short hauls, the battery may never get recharged enough. Ours is ~~ 3-1/2 years now, but because we live far from town, most of our drives are a minimum of 1 hour. So we've not done anything special, and I expect our battery will get a typical life of around 5 years.
I change mine every three years. Forgot about it in one truck and it died in me in the 37th month. Not really too bad of a cost over a three year period. |
In today's modern world, 36 to 48 months sounds about right. I always check if a "heavy duty" battery is an option for my model vehicle...and opt for the heavy duty. As an example, my Honda Civic had a heavy duty battery option for the folks that lived up in the North COLD part of the country. I added that same battery type/size.
Besides, I really have never had good luck with OEM batteries on new vehicles. Once I buy off the shelf at the dealer, those batteries seem to last longer. I agree...that Motorcraft has a decent warranty period if purchased from the dealer. biz :oval |
Originally Posted by GlueGuy
(Post 18310006)
So about 9 months ago I started letting my truck idle during my lunch break (30 minutes). I've been able to extend the life of a single battery by about 6 months but I'm burning more fuel. Just can't win. |
Also worth mentioning as the battery ages the BMS will refuse to charge it completely. I highly advise resetting the BMS. Also the BMS will re learn a new battery after 8 hours but it will not reset the BMS timeline and it will cause lack of charging and system shutdown messages.
Newer vehicles have more parasitic drains and are harder on batteries than older ones. If a person hooked up a battery maintainer overnight one night a week, i think the battery would last a lot longer. That's a hassle, so most people just replace fairly often.
So let’s expand this chat a bit. I have the following noted on my phone (my truck notes): Battery Voltage and State of Charge:
Does this look accurate? I think I got it here, but maybe from the Internet. If this is accurate, at what point would you recommend preemptively replacing a battery? I’m coming up on four years with my truck and it shows 12.4v after a good drive/charge. I was figuring when it gave me a 12.2v reading it was time to replace. |
Originally Posted by onug
(Post 18310774)
Does this look accurate? I think I got it here, but maybe from the Internet. If this is accurate, at what point would you recommend preemptively replacing a battery? I’m coming up on four years with my truck and it shows 12.4v after a good drive/charge. I was figuring when it gave me a 12.2v reading it was time to replace. Much talk of either of those up here? Scott |
What kind of battery? 12.65 volts is 100% charged at 77° F, but, that is an obsolete number for the old school basic lead-acid type battery with the filler caps to add water. Modern "maintenance free" batteries use a different plate alloy with calcium, a different chemistry. They have a fully charged open circuit voltage of 12.80 volts at 77° F. If you measure a maintenance free type battery reading 12.65 volts it's only about 75% charged. This is also the discharge level where permanent sulfation begins. The open circuit voltage is only part of the story though. Battery has to both accept, and hold, a charge in order to be considered good. A battery can also test OK for voltage with a meter but it might choke under any kind of load. An easy test is to first remove any surface charge. Turn the headlights on high for 5 minutes. Then wait at least 10 minutes or overnight. Measure the voltage across the posts. That is the true open circuit voltage and level of charge. If you can safely disable the ignition crank the engine starter for about ten to fifteen seconds while measuring the voltage at the battery posts. A good battery will not drop below 9.6 volts at 77° F. Then wait another ten minutes or so. The battery voltage should "bounce back" to the correct OCV. The capacity will be less, though not the voltage, if the battery is good. Put the charger on the battery to get it back to its happy place. If it passes those tests it should be good for a while. Maybe... |
My first simple test is to charge the battery fully with a smart charger (like CTEK or NOCO), and THEN disconnect from charger and let it sit overnight. if the resting voltage is less than 12.8, I'm worried. SOME vehicles have surprisingly large parasitic draws, so if you have battery issues, you may want to do these tests with the battery disconnected from the vehicle to rule that out.
