2000 V6 starting issue and cutting out during acceleration
Just bought it and it ran good when I test drove it. Started cutting out when accelerating and hard to get it started when first starting, starts good when warm. New fuel pump and filter installed by the guy I bought it from. Any suggestions on where to start?
Does it have the check engine light on?
If so code scan it and go from there. |
Look and see if it has a Fuel Pump Driver Module on the frame cross member behind the gas tank. See if the aluminum base looks corroded which usually will indicate failure.
2000 does not have a FPDM, that started with the new body style in 2004.
