Decode Door Tag Please
F25C9R19876
WB: 118 Color: E Date: F25C Trans: 19M Axle: F 04 GVW: 07400 Net HP: 158 RPM: 4000 DSO: 7917 |
Originally Posted by 1965GTFB
(Post 18241413)
F25C9R19876 // WB: 118 / Color: E / MODEL: F25C / DATE: 19M / TRANS: F / AXLE: 04 / GVW: 07400 / Net HP: 158 / RPM: 4000 / DSO: 7917
F25 = F250. C = 292 2V 9 = 1959. R = San Jose CA Assembly Plant. 19876 = 1959 Numerical Sequence of Assembly, the trucks specific serial number. 118" Wheelbase. E = Colonial White. F25C = F250 2WD, 7400 lbs. GVWR 19M = Assembled December (M) 19, 1958 (A = January, M = December, the letter I is skipped). F = Borg-Warner T-98 4 Speed Manual Transmission. 04 = Spicer/Dana 60 Rear Axle / 4.56-1 / 5,200 lbs. Axle Capacity. 7,400 lbs. Gross Vehicle Weight Rating. 158 net HP @ 4,000 RPM 7917 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot." |
Thanks Bill.
That's a different truck in the 61-66 forum then the '59 above. |
So do '59 tags not have any info on Interior color etc.?
(Post 18245369)
