Have a link to a good DIY fuel pressure gauge setup?
Looking for ideas. Wanted to see what you all have done or have found.
Thanks! |
Here is my setup when checking fuel pressure
https://cimg8.ibsrv.net/gimg/www.for...c317f2b59b.jpg
https://cimg3.ibsrv.net/gimg/www.for...58f2bbe520.jpg Here's my setup, working fine for 5 years. |
Originally Posted by jsm180
(Post 18204690)
Originally Posted by Thor'sHammer
(Post 18206447)
What size fitting is that between the sensor and housing?
(Post 18206447)
Fuel pressure test port thread fitting size is M12x1.5. Most gauges are 1/8" NPT |
autex 0-100psi sending unit off of amazon. Connected to the universal harness on the CTS2. Same adapter as glowshift with a male/female 45 degree elbow to point it at an angle downwards so the sensor wasn't into the radiator hose. Couldn't see spending the $$$ that Edge wanted for a pressure sensor. Their pressure sensor kit still requires the universal sensor harness extension. I was already running EGT probe, so now all the things are monitored.
nope, works fine. Examine the o-ring for cuts/tears.
(Post 18280616)
Hey, I purchased and installed this fitting and it leaks, badly. Did you have any issues with yours?
No I didn’t have any issues with it. No leaks at all. |
I figured it out. It needed a ton of sealing tape and a layer of rubber sealing compound. I think the threads are cut a little too narrow and allow it to leak some.
You shouldn't need anything on it, it's metric thread. It will go flush with the face of the housing, the o-ring will "disappear' when you tighten it. I wiped a little bit of diesel on mine and just installed it.
