Cali smog question
1999 F350 dually,crewcab 7.3 w/4" exhaust. Just failed smog. First time ever, pretty much stock except F5 that was set to stock tune and hid away. Always did this before and always passed. Said OBDII notready fail. Comprehensive Component. Asked what that was, he didn't know, take it to shop. I have know codes on my terrminator scan gauge. Can these machines now read PCM for tuners? Been this way for years and no problem. Like to here what you have to offer. Going to pull it all the way out saturday I guess. What a pain. This guy has been really easy in the pass, first thing he said, Diesel? So maybe he's scared but don't know why it would be printed on his paper work. Thanks for your help.
Found this on the interwebs, but don't know if it helps.
Originally Posted by interwebs
How the status of your vehicle’s emission systems becomes “ready” again:
Driving the vehicle in a normal fashion may allow your vehicle’s to become “ready”. However, for certain emission systems and certain vehicles, the status returns to “ready” only after driving the vehicle a specific way. This specific “drive cycle” is determined by the manufacturer. Speak to your repair technician regarding this drive cycle and what you or your repair technician should do to prepare for your retest. If you perform your own repairs and do not have a scan tool, you should drive the vehicle in a “normal” fashion for up to a week. This “normal” driving should include both “stop-and-go” driving as well as cruising speed driving. You are entitled to one free test within 60 days of every paid test, until your vehicle passes the inspection. |
Have you recently cleared codes, or disconnected the batteries? The PCM needs to see a certain amount of drive cycles under varying conditions before the readiness test is complete. Edit: I just realized Sous said the same thing. |
monitors not ready means you need to drive it about 100-200 miles because the computer is still learning. you want to split it 50/50 with highway and city driving. also the fuel tank MUST be at least half full. 3/4 is preferable.
you can check the monitors with a obd2 scanner. you have to scroll thru and check each one, such as EVAP, CAT, etc ect .... It will say monitors "ready" . under new law, ALL monitors must be "ready" for a diesel. during this time do not reset your tune or battery, that will start you at square one ....hope this helps |
Originally Posted by The Brad
(Post 18168928)
Hmmmmmm.....this darn state sometimes. It's my home, but Jeezus. Anyways, I went through the exact same thing with a '98 Volvo wagon a few years ago. You might make sure there isn't a provision for the OBDII not being ready. There was for the Volvo, but it took two months out of my life and some digging to find it out. I guess you could also take the tuner out completely. That shouldn't be a big deal.
For you other guys, do any of our tuners show OBDII readiness? I didn't think they did. |
Hey Chet...dump the f5 and give it a run for a few miles like BB nentioned. Then, hit a small town..(menifee, cherry valley..etc) one that doesnt have a high pooulation. There, ask for a PRE-Inspection. This way, its just a undocumented test. If pass, then have it redone....i remember when woodcrest was just that. A town that was once great to live in. No riffraff bs around, then it went and got itself in a big damn hurry...the "smog" garage there would pass a skateboard:-X22
I will tell you that I've never had a problem with my chip (6-position and Hydra). My 6-position chip and my Hydra don't show anything. With the 6-position I turned it to '1' (stock) when I parked at the station. I put my Hydra in my smog test tune when I parked at the station this last time. No issues with OBDII.
I'm not sure what's going on with it but if it were me at this point I would be doing what I needed to do to get it to pass. I'd disconnect the batteries (to pull the chip and reset the truck), pull the chip, fill up the tank, and drive for 200 miles. That should be enough to guarantee that all the monitors have run the course and (hopefully) flagged satisfactory completion. To hedge your bets I would follow timmyboy76's advice above and call around to find a shop to do a pre-inspection just to make sure there aren't any issues. It happens to the best of us. I learned my lesson 15 years ago with my F-150 when I repaired a radiator fan, connected the batteries, and tried to get it smogged that afternoon (only put about 20 miles on the truck). |
if they see a knob the tech might notice it and fail you because they know it's a chip. If it's tuned with SCT or hand held there is no way for them to know. Either way it doesn't matter because your monitors aren't ready, you have to drive it 100 miles and check the monitors with a scanner.
Somhow or another your pcm lost power, weather by flashing a tune, disconnecting a battery or somthing. It could also be from lack of driving if your truck if it is a spare vehicle. Your PCM controls several components of your vehicle, some of wich need to report to the pcm they are ready and working for the pcm to get proper feedback to determine if a fault has occured wich would set a check engine light. There is a prescribed sequence of events that has to occure for all the devices to report they are ready and able to function. Usualy that sequence involves ideling, driveing at various speeds for a certain ammount of time, different RPM,s, engine temp, exhaust temp, etc. Once all the paramiters have been meet than the pcm will show “ready” and can than accuratly illuminae the check engine light if its still has a wierd readig from a sensor. If its “not ready” than the right sequence if events hasent happened recently enough for the pcm to get an accurate reading from the various seonsors. This prevents false check engine lights, it also prevents people from gaming the system by disconnecting the batteries in an effort to shut off the check engine light to pass smog. long story short drive your truck for a few days and take it back, tell the tech it failed because it wasnt “ready” and ask them to do a pre check first. If it shows ready than have them do the actual smog test. |
My '02 is ready within a few minutes driving after clearing the ECM, I think yours should be too. Much of the stuff being talked about with drive cycles and fuel level is for gassers, newer diesels may also take a long time to be ready but I've never checked. I think you only have 2 monitors and they should set pretty quickly.
If you have a scanner check the monitors, readiness test. You may see some that are N/A, ignore those. What you need to look for is any that show INC, incomplete. When they show OK you're ready. If you tweaked the tune or connected/disconnected anything from the OBD port shortly before the test it could have 'reset' the monitors. AFAIK they can't see the tune and only look for the monitors to indicate everything's "OK". |
Originally Posted by viperman86
(Post 18169916)
If they look under the dash it's game over when they see that cord but so far it's not been a problem. I didn't buy the USB extension cable to pull the Hydra out, even if it's only every couple of years. Besides, the PCM connection foils aren't going to last forever doing that. So it turns out that the cheapo looking ribbon-sticking-out-of-the-dash-and-velcro-the-Hydra-head-to-the-dashboard standard mounting option was a good thing (even though it looks terrible it is very practical for me). |
Guys thanks for the replies! There was know F5 controller to see, I hid it. I think what happen was I forgot to unplug the areo scan gauge I have, bought from RR, it's terrminators version, and then he plugged in his scanner. Also It was driven every day except yesterday before the test. I drove it about 4 miles to his shop and said go for it. I don't know how the PCM could of lost power, it always starts right up and it is a daily driver, and I never discounted the batteries. I just went on a 3500 mile trip three weeks ago. I've done this for ten years like this except I always warm it up first by going down the freeway. I was in a hurry for the grand daughters party yesterday. I want to scan this before I take it back. And that's a good idea about the pretest, I'll see if he will do that. He only smogs so I'm not sure. Never had a problem with this guy in the pass, I've sent people to him even. He looked at my 4 gauges and asked after he failed me if one was a tuner. Maybe he got in trouble for something. I plan to take it back next week, I will report back what happens. I don't want to go to a referee, I do have four inch exhaust going to the cat.
Here in Nebraska, there is none of this horsechit...BUT it's Western Nebraska....IE NOTHING to do except horses and cattle. Looks like I have lots to deal with when I get back. My truck is all stock except for a Cody tunes TS chip and AFE Intake. I can just hide the knob though.
Originally Posted by BBslider001
(Post 18170205)
Here in Nebraska, there is none of this horsepoop....BUT it's Western Nebraska....IE NOTHIGN to do except horses and cattle. Looks like I have lots to deal with when I get back. My truck is all stock except for a Cody tunes TS chip and AFE Intake. I can just hide the knob though.
