Kingpin adapters - B&W Turnover, Gooseneck coupler kingpin replacement
I am looking at some different trailer and hitch configurations and am curious how the gooseneck kingpin adapters work - the ones where you swap the ball coupler with a kingpin. I know there are the kingpin + ball plate adapters, I knew someone that did that with a semi tractor. Here is an example of what I am talking about:
https://www.pjtrailers.com/options/kingpin-adapter/ I am also a bit baffled as to what the purpose is of the B&W kingpin adapter for the Turnover system. They have a few others that don't make sense to me also - the reverse gooseneck ball coupler, eyelet, ect. Of all of them the eyelet makes the most sense for an attachment point of a tow strap/chain, but not as much as a conventional class III-V rear mounted receiver. Why would you want the reverse end of a trailer coupling method to be mounted in the bed? I can't see someone inverting their 5th wheel hitch for any possible reason, for example. For what I am talking about see the bottom of page 5 of B&W's PDF catalog listed here: http://www.bwtrailerhitches.com/site...BW-Catalog.pdf |
Originally Posted by KC8QVO
(Post 18131206)
https://www.pjtrailers.com/options/kingpin-adapter/ |
(Post 18131206)
I am also a bit baffled as to what the purpose is of the B&W kingpin adapter for the Turnover system. They have a few others that don't make sense to me also - the reverse gooseneck ball coupler, eyelet, ect. Of all of them the eyelet makes the most sense for an attachment point of a tow strap/chain, but not as much as a conventional class III-V rear mounted receiver. Why would you want the reverse end of a trailer coupling method to be mounted in the bed? I can't see someone inverting their 5th wheel hitch for any possible reason, for example. For what I am talking about see the bottom of page 5 of B&W's PDF catalog listed here: http://www.bwtrailerhitches.com/site...BW-Catalog.pdf inverted gooseneck ball coupler is used with the ball on the trailer and is secured with a pin in the coupler on the truck. Eyelet is similar to a gooseneck but couples differently I think. I have seen these at farm auctions on older trucks with home made trailers. The kingpin one for the truck has a small fifth wheel head on the trailer upside down. It is actually what the binkley fifth wheel head that the air ride trailer saver brand fifth wheel is made for. My assumption is that some of this is for a theft deterrent. Pick something goofy and it is harder for someone to borrow or steal. |
