Adding Grab Handles to 1997 - 2003 Econoline Van
This should work for any van from this time period. Mine is a 2000 E150.
I have people complaining how hard it is to get in and out of my van. So I needed to add grab handles. I looked at different options and thought, hey maybe the 2003+ ones might fit. So I went to the junkyard and got both pillar trim pieces and handles for $10 total. The trim piece clips fit perfectly into the existing mounts. The only thing you need to cut out is the top white bracket. To locate the handle holes I just put the handle in place and marked the hole with a black marker. I drilled a tiny pilot hole, then the full size hole, then used the proper size tap for screws the handle used (I'll add the exact size bits later). The thing is solid as a rock. Just be careful not to over-tighten the bolts. https://cimg5.ibsrv.net/gimg/www.for...beac2d73c7.jpg https://cimg6.ibsrv.net/gimg/www.for...dcd28668de.jpg |
Wow ….. good job!! I'm glad my 2003 already has them from the factory, because you're right, they are DEFINITELY NEEDED !!! I had to add a few grab handles/straps around the side doors also, to help ease entry/exit concerns, along with anti-slip industrial tape on the footwells all around the vehicle. Other than that, it has been a great highway cruiser ….. :)
Originally Posted by econovanfan1
(Post 18084724)
I had a buddy that worked for a Ford dealer who told me that a customer came in for the passenger grab bar that was broken be replaced under warranty. This customer came in the second time for the same problem and again was replaced. On the third time for the same problem, his wife accompanied him. Service manager denied the repair after seeing his 400lb wife. :-X24
Originally Posted by Chad Clark
(Post 19822098)
Do you have any pictures of the grab handles/straps that you installed on the side doors. I'm really wanting to add something like this to make it easier for the kids to get into the van. Thanks!
(1) Jeep headrest handles: https://cimg7.ibsrv.net/gimg/www.for...66503e61c2.jpg (2) Strap handle (from Nissan, Cadillac, many other makes) https://cimg3.ibsrv.net/gimg/www.for...2d1a5ef1a8.jpg (3) Seatbelt loop handle https://cimg6.ibsrv.net/gimg/www.for...0a948fc93f.jpg |
E-Series vans factory equipped with the A-Pillar grab handles have reinforced areas under the attachment points---this makes them far safer than simply using a sheet-metal screw holding them in place. The factory parts will fit vans back to 1992 BUT the trim pieces do have a top clip that requires the headliner to be trimmed OR removed as this OP might have done. That would be personal preference as its not an essential part of this particular installation.
I have a 2000 that will be fitted with factory grab handles but I'll use what are generically called "plus nuts" inside the A-Pillars, the factory threaded fasteners so they've held in place very securely. This makes them safer over the long term, little to no chance of the sheet metal tearing or the holes being enlarged from repeated use. |
(Post 19822098)
https://cimg2.ibsrv.net/gimg/www.for...cb347e255c.jpg |
