who makes NAPA Commercial flooded cell batts?
This wasn't my 1st place to ask this, but there is so much knowledge here I figure it is the BEST place to get a correct answer. I need to replace the starting batteries in our motor home (pronto). They are a group 31 sealed flooded cell. The ones in there now are 7 year old International's, but there isn't a convenient place to get those. However my local NAPA store has them in stock for a very good price. Several Googles and From all I can find: East Penn makes these batteries for NAPA (or Deka makes them for East Penn for NAPA). I'd be pretty comfortable with these if that's the case. Anyone know? Oh yeah: NAPA's part number is BAT 7236, if that helps...
Thanks in advance... Scott |
I wouldn't mind know either. I have two of NAPAs in my truck and they've been awesome for almost 4 years and no signs of letting up.
DEKA does brand batteries for NAPA.
You can try and look here, especially if you have insomnia http://jgdarden.com/batteryfaq/batbrand.htm |
Can you get an MSDS on the battery. At one time, their SDS documented that East Penn manufactured at least some of the NAPA batteries.
Deka is a brand name of East Penn I believe. https://media.napaonline.com/is/content/GenuinePartsCompany/686481pdf?$PDF$ https://www.power-solutions.com/batteries/deka http://www.eastpennmanufacturing.com/wp-content/uploads/2017-Deka-Spec-Sheet-Final-Rev-4-10-17_FULL.pdf |
I've always heard good things about e Penn. Didn't know Deka was them. Makes sense why my boat batteries are good...they're dekas
Thanks for the correct link Jack.
Looks like that battery is their 1131PMF battery. http://www.eastpennmanufacturing.com...10-17_FULL.pdf |
Scott, a couple 8-Ds would fix you right up. |
Speaking of HD type wet cells what about Trojan Batteries?
I had good lick with them in the boom lifts and forklifts. |
Thanks Jack and Mark -- I looked the spec sheet over and I think it is the one without the P (1131MF) same battery but with just stud post terminals. Jack: you know I looked all over for that 8-D battery, then I got the smile: 2 sets of 8-D cells -- you funny guy...!
Sean: I have Trojan Batts in the golf cart -- they have a really good reputation in the cart world. Mine are 5 years old and I do keep up on the maintenance - they show no signs of aging. And of course I recabled the 6 - 8 volt batteries to all 4/0 and a couple short 3/0 cables to interconnect them... :-jammin Thanks again everyone! Going to go get me some Napa's.... Scott |
1800 CA each, you would always have cranking ability with twins. Just trying to help in wild. These I use my front end loader to install in the dozer. You can even get AGM. https://cimg2.ibsrv.net/gimg/www.for...3eb4fa7478.png |
My GOODness!!! so there are 8-D batteries... One of the nice things about the MH is it a) has a Kubota Diesel Genset, b) 3 Group 27 House batts and c) a switch on the dash you can tie all 5 batts together -- either to start the rig or start the gen., but I think if I just change the twin 950 CCA batts out every 5 years or so, it should be fine...
Moved 18 tons of gravel, speaking of tractors, but I ended up doing too much work by hand so pretty wiped today... Scott |
Yeah, I had to put the - in-between or it came up a smiley.
(Post 18053099)
Think I drain the oil tomorrow morning - I hear it is a messy job getting the oil filter out on these 5.9s -- there's something called "the plastic bag trick" - I have a feeling I know how that is done... Then off to the Drs and pick up the batteries on the way home... Scott |
Hey Scott - have you been posting on BITOG recently?
