Inertia switches
Any of you guys that are running a fuel injected engine with electric fuel pumps using an inertia shut off switch? I'm not sure if I want to incorporate this into the build, from what I've been able to read about them a good sized pot hole could trigger it. I'm all about safety, but not at the expense of having to hassle with reseting the thing at every bad road we come across. Y'alls input as always is greatly appreciated. Thx.
You could go with the oil pressure switch set up but being injected it might run for awhile. None of the injected Fords I've driven have ever shut down on potholes or bumps. F350 dually was a rough riding truck too. Most of my trucks inertia switch in the right hand kick panel.
I still have mine intact, it has not given me any grief,never gone off and I've gone now some nasty bumpy roads.
https://cimg3.ibsrv.net/gimg/www.for...3bb5c17c2.jpeg Never had any such problems with mine safety first. |
OEM's have been using them for decades. I've never had an issue with any of my new cars with them. It's not something you hear about being troublesome in the news, and if cars were shutting down all the time from rough roads, you'd hear about it. I don't think you'll have any trouble with one, as long as the one you use isn't defective. I see no reason not to scrimp, here. If you were ever to be in a hard crash and the fuel didn't shut off, you could have a really big "hassle."
I appreciate all the input, do any of you have a part number for a switch thats tried and true? Thx.
Mines out of a 89 crown vic
The only issues I've heard about is when someone drives over a curb, etc. and slams the bottom of the vehicle against the pavement. Usually hard enough to jar your noodle. It's kind of a handy thing to have, not having the pump continuing to push fuel all over following an accident. Just place it somewhere not too difficult to reset and in the same orientation that it was in the donor vehicle (right side up, not sideways, etc.)
Originally Posted by CBeav
(Post 18043299)
Below are a couple cut away's of the Ford inertia switch, they are the epitome of the "KISS" principle. https://cimg8.ibsrv.net/gimg/www.for...7566d463bb.png https://cimg0.ibsrv.net/gimg/www.for...c9cd263e15.jpg |
Used mine as antitheft on the town car we used for trips. Stop at motel for night while unloading luggage I would tap the switch with tire iron. Load up next morning and push reset.
i've been kicking around the idea of using one on my truck, i just could never get see a straight answer on how to wire it. Through the ground wire to pump, through pump relay, through pump trigger wire coming from ford controls pack...
Let us know what you find out. |
In trucks the inertia switch went between the fuel pump relay and the fuel pump cutting main power to it. The Interial switch should cut main power in the fuel pump circuit and not the control power to the fuel pump relay.
In my mind the less unnecessary stuff wired in the less chance of trouble . Why do you feel you need one ?
Originally Posted by matthewq4b
(Post 18044776)
Originally Posted by EBEAR
(Post 18044777)
