Looking for 4 11 gears for 1957 Ford F350
https://cimg3.ibsrv.net/gimg/www.for...d4846c7c8e.jpg
https://cimg1.ibsrv.net/gimg/www.for...00faec7054.jpg Axle Plate I am breathing life back into a 57 Ford F350 and I am trying to get more that 50 MPH out of it. It has 5 14 rear end. Was told I could get 4 11. Does anyone know where I could buy one? or have any suggestion on a different axle that will swap out without a lot of work? I am on the road working in Cape Cod and only go home for 3 days at a time and would have to pay someone to do most of the work. Or any suggestions....It has a 1964 390 4 speed. LOW GEARED. can start off in 3rd. I would like to use it as a daily driver eventually. I am more of a body guy...not a mechanic. Any other Ideals Mark from Missouri |
1957/58 F350 has a Timken model B100 rear axle. Available ratios: 4.86-1 ~ 5.14-1 ~ 5.83-1
Dana 70 rear axles introduced on some 1961/62 F350's, all 1963/66 F350's have the Dana 70. All 1953/66 F350's have 6 lug wheels on a 7.25" bolt circle. 1967/97 F350's have 8 lug wheels on a 6.50" bolt circle. |
Building on Bill’s comment, the Dana (Spicer) 70 axles in 1963 (based on my 1957-1963 Chassis Catalog and presume the same through 1966) could have been spec’d with a 4.10/1 gear set. There were two axle cases, 4.56/1 ratio and up and 4.10/1 and down numerically. The cases that were coded with #s 26403, 31708, and 30786 could/would have the 4.10/1 gear set. The part number for the 4.10/1 gear set is C6TZ 4209-H. The Ford number for this D70 case is C9TZ 4204-B. All of these would have hubs and wheels having the 6 x 7.25” pattern. Stu |
2 ways to go, get an overdrive tranny or change the rear axle. I have the same diff as you, I put in a auxiliary box with 15% overdrive. I can get 65 at 3,000rpm. I used to run about 3,400 rpm and get 55 at least. But my truck still has its 292 in it. And it got 11mpg at the time.
Originally Posted by truckdog62563
(Post 17956909)
Building on Bill’s comment, the Dana (Spicer) 70 axles in 1963 (based on my 1957-1963 Chassis Catalog and presume the same through 1966) could have been spec’d with a 4.10/1 gear set. :-huh This is incorrect, it's not your fault because you are unaware, but I know. Notice in this pic of parts list 96 (scroll down a bit) that the Ring & Pinion part numbers reflect 1966: C6TZ-4209-H & C6TZ-4209-K The original loose leaf paper parts catalog for these trucks was for 1957/69, so this is why some of the application charts in this catalog say 1963/ In 1970, Ford removed the loose leaf pages for 1957/63, then placed them in 3 bound paper catalogs. I have two of these original 1957/69 loose leaf paper parts catalogs and a complete set (3) of the 1957/63 bound paper catalog, two text, one illustration. https://cimg5.ibsrv.net/gimg/www.for...f8a1ca8ba5.jpg |
Thanks Bill. I stand corrected and will bookmark the info for down the road. Stu |
