PCV System Questions
First time here - I posted this is the 300 4.9l forum but didn't know if it'd get seen so I'm posting here as well. Admins can delete if that's against the rules. Sorry if so!
First of all, let me be very clear that I'm new to almost all of this DIY stuff, especially on older trucks like this. My experience totals changing Radiator, Alternator, serpentine belt, and oil changes, air filter, etc. That was all on a 99' Ranger. Long story short, I just bought a 1985 f150 with the 300 4.9l straight 6 a couple days ago. I was so excited to buy it, I didn't even ask the previous owner about some obvious things. lol. I changed the oil today and clear water came from the plug. Also noticed some oil leaking and accumulating at various spots. Looked around and it became glaringly obvious (to me anyways, could be wrong) that the PCV system is all jacked up. I don't really even know where to begin. A lot of the hoses are cut, the oil cap is solid and all the holes are empty where it seems there should be some hoses coming up out of the valve cover. Anybody care to give some thoughts or point me in the right direction. Again, I'm very green at all of this so any help at all is appreciated. It seems to run really well though. Pretty quite and no odd noises that I can tell. Here are some picture hopefully. I've only driven maybe 50 miles since buying it. https://cimg9.ibsrv.net/gimg/www.for...e4cb2d657c.jpg https://cimg3.ibsrv.net/gimg/www.for...5bf44808d6.jpg https://cimg0.ibsrv.net/gimg/www.for...2862882149.jpg |
1985 F150 4.9L (300) I-6
Upper pic: Air cleaner and misc parts:
Lower (upper) pic: PCV system (caption should read 1980/86). https://cimg4.ibsrv.net/gimg/www.for...1102a19f37.jpg https://cimg7.ibsrv.net/gimg/www.for...b166fa7f53.jpg |
Look at that uncomplicated engine compartment ~ not a mess of tubes, wires hoses cables and whatnots in the way of anything you want to do ```
Oh~ at the base of the Carburetor ~ I see a couple tubes that might have had hoses on them at one time ~ see if they're drawing air ~ put you finger on them with the engine running ``` I don't remember if the wipers had vacuum assist on these ~ look around you'll be able to figure this out ``` One of the guys may come up with a diagram for you ``` Re: water in on under the oil ~ On a 66 Buick Riviera ~ I found a casting hole in the water pump ~ but sense the water was clear it could be condensate ~ or poured in by a kid playing ~ a lady gave me a van ~ I found her kid had poured water in the engine playing Fireman ~ if the engine had run with the water in ~ it would have made the oil milky ~ so I don't think it would be a head gasket or Aluminum head problem ``` Good luck to you ~ this is going to be more fun than worry ``` |
