2008 f350 diesel . slow acceleration
I just bought this truck it runs good but slow on accelerateion no mil lights are on. back pressure pipe maybe? someone suggested the torque converter. also the psi goes to 20psi max. doesn't want to go . seems to lack power. runs good on highway, but getting up to speed takes too long. the big rigs accelerate quicker. regen works ok. doesnot leak or smoke any suggestions |
Almost sounds like limp mode. But you are saying no lights. Maybe plugged dpf but again that should cause a light. |
To be clear, limp mode might just be the wrench in the info screen, not necessarily a check engine light.
The first thing I would do is change both fuel filters and check your air filter. You can do a torque converter stall speed test in a parking lot, but I wouldn't expect your issues are there. I have had a few of these trucks over the last couple years and they are not all created equal, some are reasonably perky and others a bit sluggish. |
thanks for the replies. here is some more info
I got this beast of a truck at a car auction. it was a theft recovery. so the ignition electronic ring was pulled out, and the radio was disabled...I got it cheap.... also, the shift lever actuator is acting up too. I have to manually pull out the white little plastic piece in order to shift, sometimes. this can t be it, I'm assuming, so I didn't bother to fix it. but the security, anti theft is disabled. this could be the issue? there are no lights on. no wrench. no codes.... |
Interesting history - chances are it has sat around for a while. You should be able to get more than 20 psi easily. Check the vgt to be sure that the turbo isn't stuck in one position. With the key off you should be able to work the vgt solenoid linkage by hand. One other item to check is that the egr valve isn't suck open. I know you don't have codes or lights, but it doesn't take long to remove the egr plastic cover and work the plunger up and down with vise grips. There are a few threads one here showing how to remove and clean your intake manifold pressure sensor. You will be surprised at how full of gunk it is when you remove it. If this is clogged and the computer is not seeing the boost, then it may not be fueling correctly.
