1979 ford f700 370 4V cal truck
Hi I have a 1979 ford f700 with the 370 4V. It is a California truck and i need to know where the vacuum lines go. Need to smog this thing. Thanks for any help you can give me.
Welcome to FTE.
Are there capped or plugged vacuum lines all over? Is there a sticker on the core support or on the underside of the hood? A sticker on the valve cover? The basic emissions sticker will confirm, if you have not already, CA vs. 48 state emissions. Any evidence of other tampering? CA law says the seller is supposed to smog, so good luck with this. The vacuum diagram is in the shop manual and several folks have those, so stand by. |
Thanks. Unfortunately there are no stickers anywhere. I am sure it is a california truck. All the smog stuff is there I just need to know how to run the vacuum lines to the switch on the valve cover and then to the EGR. I think the carb only has two jets one above and one below. There is one port straight off the manifold. I had the thing rebuilt years ago and I got it back with no line to the EGR. Any help will be greatly appreciated.
Originally Posted by 1979fordf700
(Post 17860205)
Thanks. Unfortunately there are no stickers anywhere. I am sure it is a California truck. All the smog stuff is there I just need to know how to run the vacuum lines to the switch on the valve cover and then to the EGR. I think the carb only has two jets one above and one below. There is one port straight off the manifold. I had the thing rebuilt years ago and I got it back with no line to the EGR. Any help will be greatly appreciated.
Look on the 3rd line-far right of the Warranty Plate, riveted to the left door face below the latch for the DSO code. Post what it is. |
dso code
I have to go to the library to get on line will be able to get the code tomorrow. Couldnt get logged in yesterday. Thanks for the help.
The DSO Code on my 1979 Ford F700 is 52 NumberDummy. I am so thankful for your help.
1979fordf700
Hi everyone. I have had a 1979 F-700 with the 370 V-4 engine. I need help smogging the truck as I am in California. The DSO code is 52. I hope I can get help with this as I am at a loss.
1979 Ford F-700
Hi there NumbersDummy. I have the 1979 ford f700 that has a 370 4-V California engine. The DSO number is 52. I need help hooking up the vacuum lines. It has a V-4 on the cab of the truck. Any help would be greatly appreciated.
Welcome to FTE! :-X22
What's a DSO code? |
"District Sales Office" and "Domestic Special Order".
Ford's DSO Codes - ???Gary's Garagemahal Post 4: https://www.ford-trucks.com/forums/8...dso-codes.html |
Threads merged. This is a tough one to get answers on apparently. There has got to be a vacuum diagram in the shop manual for this thing. Stand by now that you have the DSO posted.
Every time you post it brings the thread to the top, so a new thread is not needed to keep the question up at eye level. |
Originally Posted by johnsteele707
(Post 17882132)
Hi there NumberDummy. I have the 1979 ford F700 that has a 370 4V California engine. The DSO number is 52. I need help hooking up the vacuum lines. It has a V-4 on the cab of the truck. Any help would be greatly appreciated.
Why is the 370 4V from CA? DSO would be 71 (Los Angeles) or 72 (San Jose). You will need a shop manual, or at least a vacuum diagram. I have neither. Try: faxonautolit.com |
(Post 17882115)
Since this truck was not sold new in CA.. it will have a 49 state vacuum routing. Some sold new in CA trucks have different emission parts than were used in the 49 states. What I would do is say nothing about its origin and take it to a smog station and have it tested. There is no charge if it doesn't pass and usually the smog station will tell you why it didn't pass. |
Posts merged again.
How long has the truck been in CA? Any record of prior registration? |
It was a Hertz truck. I guess I will buy the shop manual, thanks Number Duumy!
