Pulling the 5.4 soon
Greetings,
Having built the replacement 5.4 with all the goodies, I now need to pull the existing motor, a 5.4 as well. I'm curious where to hook the chains to that would be strong enough to hold the motor. Thanks |
I normally bolt it to the block where the alternator bolts up and to the back of the cylinder head. It works pretty good but I always pull the intake manifold before pulling the engine.
Originally Posted by lwarrior1016
(Post 17815470)
Oh man, trick flow heads! Post some info up about this build. You’ve got my interest lol. What are you using for cams, did you get trick flow spec’d cams? |
You realize the stock i take can't flow for nothing right? Ive been wanting to do this type of work th my 5.4 but unless you go full custom built intake its pointless
You can use any 4.6 2v intake that you want too, if you use the 5.4 adapter plates. The edelbrock 4.6 intake works really well on the 5.4. |
(Post 17815631)
Oh man, trick flow heads! Post some info up about this build. You’ve got my interest lol. What are you using for cams, did you get trick flow spec’d cams? When the time comes to rebuild my 5.4L 2V engine, I'd love to try TFS 185 heads, custom "truck" cams and a 7.3L turbocharger AKA Roadkill Rotsun 5.0 Ford style...lol |
Yes maybe in a f150, but in a super duty platform you need low end power not 5k up power
For those that wanted info on the build:
Ford Motorsport block Trick Flow 2V 185CC 44CC Chambers 90lbs springs Wiseco Pistons 16cc dish 10.9 Compression Lightning Crank Molnar Rods Comp Cams 224/226 Duration 550/530 lift Billet OIl Pump Boundry Pump Gear All ARP Cams Degreed Balanced |
Originally Posted by flyingtexan
(Post 17940786)
Yes, I should have just bought a Raptor and called it a day. It's definitely my forever truck.
Any updates on your build? |
