plastic fuel filter on the top of the engine
in my previous 6.7 power stroke TD the plastic in line had 2 inlet/outlets, now my 17' has a third one that's thinner, and smaller. just trying to understand why Ford made this change and what purpose does this third inlet/outlet serve.
thanks |
The third inlet is for filling/priming the fuel system when the truck is built. The first filter that comes on the new truck has 3 inlet/outlets. All replacement filters only have two. Your last 6.7L would have had 3 also when it was new, you may just not have noticed at the time.EDIT: I stand corrected. I didn’t realize the 17 actually had the third line. |
Grayson, the 17’s have three that are plumbed up. I’m not sure of the purpose of the third either.
I believe the third is the return line to the tank on the 17s
thank you for the quick response.
Originally Posted by graysonp
(Post 17748852)
Your last 6.7L would have had 3 also when it was new, you may just not have noticed at the time. I also completely forgot about the fastener that holds the engine mounted filter in place. Either my truck doesn't have that fastener or I got lucky and removed it without needing to loosen it, mine came out relatively easily with a counter clockwise twist. |
Originally Posted by dirthawg
This is not always the case. Ford must have made a change at some point. I changed my fuel filters for the first time this last weekend on my '16 with only one inlet and one outlet. I watched a few youtube videos to get familiar with the process before changing mine and noticed they all had a 3rd pipe, so when mine didn't have that 3rd pipe I noticed right away. Those trucks in the videos were 2011 and 2012's FWIW.
2011 -2016 MY original from the factory will have three tubes, but the tube closest to the grill will be sealed. When you execute a filter change there will only be 2 tubes. 2017 MY replacement filter have 3 tubes and 3 connections.
Originally Posted by F250_Super_4X4
(Post 17750211)
Original filter I removed last weekend. Pulled it out of the trash to make sure I wasn't mistaken. https://s20.postimg.org/h3yborhzh/20180124_181027.jpg https://s20.postimg.org/lpufxbdv1/20161219_144042.jpg |
My 16 only had two tubes from the factory.
