Limited Slip
Does anybody know if someone makes an aftermarket limited slip for the 2017 10.5 Sterling axle? I looked at Eaton Detroit Trutrac but on their website it only went to 2012. Are the rear axles the same? Reason I'm asking is I have looked at a couple of used 2017s but they don't have the E-locker. And I would prefer a manual shift 4x4 instead of ESOF. Its very hard to find one that is still manual shift with an E-locker. Thanks.
Call your local dealer and see if a 2016 factory limited slip case will work. Otherwise, you may have to wait for the aftermarket to catch up.
I'm pretty sure that Truetrac will work. I don't know of anything that has changed since then. Any 35 spline Truetrac should be GTG. Call Randy's. I'll bet it's just a bad website list.
You can also try a Detroit Locker, or Yukon Locker in the rear. |
Thanks for the heads up. I'll make some phone calls and see. I want a limited slip over a fulltime locker. Fulltime lockers suck in ice and snow.
Looking at the Ford website I see the 2018 F250s with the 6.2 only come with an E-locker with the 4:30 gears. But you can get a limited slip with the 3:73. Are the axles different between the 6.2 and 6.7 PS?
Reason I'm asking is I was looking at 6.7 PS. I have looked at the 6.2s as well. And may still go that way still just really leaning towards a 6.7. Thanks again.
The e locker on the trucks you pull out the knob to activate it when you want it locked and it's only in LOCK up to 20 mph then it disengages. It's not a full time locker
I'm tracking on the E-locker, I was replying to Buliwfy about the Detroit Locker which is a fulltime locker.
Originally Posted by uh60
(Post 17744771)
Originally Posted by Buliwyf
(Post 17744568)
(Post 17744610)
(Post 17744271)
Ford Sterling 10.5" Axle Rebuild - Four Wheeler Magazine |
Originally Posted by P.Bronner
(Post 17745030)
Agreed, I don't know of any changes to the rear axle. Get the True-Track, they work great. Smooth and quiet, no chatter/clunk.
The true-track works great. Smooth and seamless. I have an FX4 (so its an E-locker) but if I were daily driving in snow I would want the LSD (true-track) instead of the E-Locker. If I were plowing snow I would want the E-Locker. |
(Post 17744615)
Thanks for the replies
