1994 E250 e4od transmission slips in reverse
Hello, I have a 1994 E250 cargo van. It has a 5.8 engine with an e4od transmission. It will drive just fine in forward but seems to hesitate in reverse. Almost like the brake is on. It will roll in neutral just fine also. It will roll in reverse but takes a lot of power to do it. It will not pull itself up hill in reverse. I have dropped the pan and installed a new filter and new fluid. The pan did not have any metal shaving in it. Help
Are you sure it's a transmission problem and not a rear drum brake problem?
Assuming it's drum brake, might be worth pulling the drums for inspection. I broken spring or something could have a shoe binding up? |
With the engine running will it roll backwards in neutral?
I did pull the passenger side brake drum and it seemed okay. I was able to rotate the wheel by hand in neutral. It rotates very good in a forward motion but not as well in a backward motion. I jacked up the other side and was unable to break the lug nuts loose. The wheel on that side rotates the same as the other side while it is jacked up. The van will roll backwards down my driveway in neutral. But my driveway has a pretty good slope to it.
Originally Posted by Mark Kovalsky
(Post 17743757)
Then I suspect something in the brakes. If it only rolled forward in neutral it would indicate that the forward clutch had failed.
(Post 17744912)
That does sound like the forward clutch could be stuck on. What does the fluid look like? Red/brown/black? Does it smell burnt?
(Post 17745617)
The fluid did have a brown tint to it. I did not notice a burnt smell. I dropped the pan and put in a new filter and new fluid. There was no metal shavings in the pan just black sludge around the magnet. It seems to drive in forward with no problem. It does seem to shift into overdrive way too soon. |
Well now it does the same thing in 1 and a little in drive.
Anyone have any other ideas? Do I just need a rebuild?
Originally Posted by Tim Foster
(Post 17755287)
toast, sorry
Thats how mine started to go, Reverse started to slip then chatter really bad, Then a few months later forward went.
