turbo chirping has begun
well, the infamous turbo chirping has begun. sound is from the vanes/vane acuator system and not really from the turbo bearing. the acutal sound is like predator birds or ravens squaking.
so another thing to put on the list . |
What's your plan of attack? Is it Hi or low pressure side?
Any loss noticed in performance or boost or just the audible? Denny |
It’s strange
It hasn’t happened again. |
Thanx Fritz,
Think it was a mod sinking in? If it rears again, do you have a plan in place. Knowing you, you had a 4th and 1 plan in the mix. Denny |
im contemplating putting in a 60ml injection nozzle before the turbo and mist some oil onto the variable vanes. 60ml would be just enough to keep it wet.
I can tap some off my oil bypass filter line (5PSI to 60PSI). |
Your talking hi side from what I gather. Correct?
Sounds like blistered paint kinda, can you expound? Appreciate your innovative aspect on this rig. Denny |
Is it turbo chirping? Or broke exhaust manifold bolts? My truck was making a chirping noise for probably a year. And it would come and go, some days it would do it a lot, other days none. Then one day it was horribly loud! Had 3 exhaust manifold bolts broke on one side, and 2 bolts broke on the other side.
Originally Posted by CampSpringsJohn
(Post 17746201)
Just back from a 400 mile round.
Heavy snow, ****ty roads and I just noticed slightly off throttle I had a bird up front. I'll see tomorrow if it's still there but will check manifolds first. Denny |
No loose or missing man bolts. Washed the truck top to bottom. Went away. Thinking it was a belt noise from the salt and ice spray on the trip.
Fingers crossed. Denny |
Anymore word from this? I had and squeal today on heavy throttle. Was riding with the shop mechanic trying to figure out my vibration issues. It happened twice. I was getting on it pretty good. I am hoping it was a fluke as well. Do you guys have a sound clip of yours?
Mine did it once when I punched it during regen |
I HOP it was a fluke. Really do about broken manifold bolts causing this as well. And they are a giant pain in the rear from what I have read. I would think that if the truck was cold and did that it make have been a manifold bolt. But the truck was warmed up when it did it for me.
Originally Posted by Firefighter 1406
(Post 17786015)
