Disc brake swap question
I am changing the drum brakes on my 1966 f100 to disc brakes from a 73-79 f100 set up. I am going to use the 66 I beams.
I have read that I need to use the 66 kingpin when doing the swap. My question is on the bushings, I see that there are two bushings, do i need to replace these also? Or will they stay in? I am bringing the axle and drum spindles to a shop to have the kingpins removed and then the new disc spindles pressed back in. Thanks |
New king pins, you should use new bushings. If your having a shop remove the old ones, get a kit with bronze bushings and the shop will ream them to the final spec. I tried to do it myself and bought a kit with the nylon bushings. No problems so far. But I still ended up taking them to a shop because I couldn't get them apart.
And make sure your kit has a lot of shims(8-10). I needed 3 on each side and they can be a bear to find.
Here is a link that show some of the differences. Comparing I-beams and Spindles - FORDification.com
This chart was helpful. I see the difference is in the length of the king pin
1966 6.35 75-79 6.49 I believe my spindles to be from a 75-79. I guess i should remove the pin and measure, then i will know for sure. I was hoping to buy in advance. Would it matter which length? I know it may be a stupid question, but i was able to drive one out and it seems to me there is plenty of pin even if i used the shorter one? Feel free to correct me. |
Spindles
1 Attachment(s)
If you read that page you will see that their recommendations were based on the steering bump stop more than kingpin size. I don't know what sort of mixing and matching you can do and have it all work together. If it were me I would try and get the "I" beams that go with the spindles you have. Also if you get the "I" beams and radius arms from a 75-79 you will have the option of adding a sway bar if you can find the brackets that slip over the radius arm. Here is a page I downloaded back when I was looking for a stabilizer bar and brackets for my truck. It took me awhile to find the parts. Apparently not many people wanted to pay extra for that bar. Adding it made a big difference in body roll.
Thanks for all the help.
I plan on using the 66 axles and the 75 spindles. I only have the later spindles. I did not get the axles. Unless someone tells me i am wrong? I thought i read this was ok. |
