What do you have to remove to remove the PCV tube from the intake?
What do you have to remove to remove the PCV tube from the intake? I have felt around back there but I can't find it. Any help would be greatly appreciated.
1999 f150 5.4 4x4 auto |
Originally Posted by 1999-F150
(Post 17721024)
1999 f150 5.4 4x4 auto -- Rick |
Originally Posted by Rick NoLA
(Post 17722194)
If it's like mine, it's a one-piece hose/fitting assembly. It's not a mechanical fitting. The larger rubber end is usually seems a bit stuck to the intake from heat. I use a wide-bladed screwdriver and my fingers and gently work around the edges of the fitting to pry/ease it off.
-- Rick |
Mine is on the back of the TB and pointed directly at the firewall. It angles upward a little.
The TB does not need to be removed. Both ends, the PCV and the TB are just tight rubber connections. The large end of hose goes over outlet on back of TB.
