Pull Door to get the Bench Seat out?
Hi!
Do I need to pull one Door to get my Bench Seat out of the Cab? (F150-77 Regular Cab) Thanks! |
No. But you will need a friend.
Should not have too I pulled my seat out to have it redone and I have a 73 F-250 no problems whatsoever!
Good! Thanks a lot guys!
I removed the standard bench and put what I call bench buckets out of an '84 in (significantly taller back) without removing a door in my 74 regular cab. My problem was available help...........she didn't so much as %%tch about it but her pessimistic attitude about it fitting as she held the other end was a real buzz kill..........pick your help with that in mind.........just say'n.
Its easier to take the two hinge bolts out an remove the back of seat and then the bottom seat
Thanks!
Good suggestions!!! |
Originally Posted by 72rtchallenger
(Post 17680121)
Why not just fold the back forward? If you put a towel under the bracket, and drag it out of the passenger side, you wont be fighting the steering wheel.
i just pulled mine out by myself by putting a 30" long piece of 2x6 lumber under the driver side bracket so it could slide as i pulled it out the passenger side. Mine is a Standard, i have the shifter pulled out as well, but i dont think it would interfere much anyway. I let it fall to the ground and stood it up on end. Im going to wait for help to put it back in though!
Once again. Thanks a lot for all good suggestions!!
Now I am just have to choose between my wife and a piece of 2x6 lumber!!:-X04 |
Yep
Originally Posted by Matt1966
(Post 17685003)
