2008 6.4 l turbo diesel idle?
Where is the idle adjustment on a 2008 6.4 l turbo diesel?
Why do you ask?
Tell us a story. How high is it running and are you deleted, etc... Denny |
I don’t think there is one as everything is fly-by-wire controlled by computer.
From what i can see it has the EGR deleted. It is running 950 to 1000 rpm.
Idle speed is computer controlled.
Spec,
When I bought my truck 08, it was allready dpf deleted. It idled at 950-1000 and it was unmanageable in parking lots etc. When I researched the cause it all came down to the sensors/probes in the exhaust. I crawled around and found that I was missing the furthest back probe. I bought and installed it into the harness where the connector was empty and my idle dropped to 600-625. All good. Is your dpf removed?? This could be your problem regardless. Denny |
Computer controlled and influenced by tune - some tuners had high idles.
What is a few of the best tuners out there for the 6.4 diesel? I did not get a tuner when i bought this truck used and there is probably no way to tell which tuner was used is there?
I have a Mini Maxx and i’m Pleased with it.
- connect the first time to select make and model - connect the second time to program - put it back in the box |
