Adobe Reader
Hi,
Adobe Reader has been barking at me lately to 'upgrade' to the DC version -- I have XI. A couple of years ago, I did that, and found it fairly horrible. I couldn't find some fairly common functions -- although maybe they're all now tricky little icons. At any rate, I managed to get back to XI and have stayed there since. Donjamer told me at the time that DC was not a good deal. Now, I have to shut down the update message every day at least. Then today, I checked for updates from within Reader itself. It reported that XI was no longer supported, and that I should get DC to get the latest updates. Of course, they mentioned 'security updates' just to make it seem important. Anyody using DC? Hows that working? I use pdfs quite a bit and I'd hate to be restricted by this 'improved' version. Thanks, hj |
HJ
What do you use Adobe reader for?? If it is just opening and reading PDF files then nothing will change.. I don't remember what we discussed before on the subject.. I have been using the DC version for a while and have not had an issue reading the files |
OK. maybe I'll give it a try. Seems to me that I couldn't rotate pages or some other thing that I do occasionally.
Also, I make my own tax calculating spreadsheets, and to do that I copy the current tax tables into excel. ( It takes a few steps, but it works). Can't imagine that they'd drop that, but who knows. It just seems that every time somebody is really pushing a new version, some feature has been omitted. Thanks, hj |
I just tried and I can rotate the page so that should work..
As for the excel tables you will have to try that.. If you find limitations there is a website that you can create free PDF files and also edit existing ones.. You can check it out.. I have used it a number of times for what i needed https://www.pdfescape.com/windows/ |
Yeah no need to use adobe reader for what you need it to do. Lots of online tools nowadays!
Thanks as always DJ. I don't really do anything special to make tables -- it's just a cut and paste, but it's something that I'd hate to lose.
Probably check out the online stuff first -- then I should have a backup . hj |
