V10 in an RV
3 Attachment(s)
Hi all,
I have a new to us 2010 Winnebago with the V10. It has low miles, so I am wondering if I should be pro-active and replace the manifold studs now rather than later. They are fairly easy to access in the truck frame, but I don't want to open a can of worms either. They do look a little rusty, have not failed yet, but with now 16k miles on the engine maybe easier to get them out now? Here are some pics from one side. Can I replace one at a time without removing the manifold and replacing the gasket? |
I think you should be prepared to open a can of worms. Lots of great posts in the history of this page on replacing broken studs. I would go for it.
If it isn't broke why try and fix it, I had 2 V10s one still had the original studs at 300+ when it died (I no longer owned it at that mileage) and the other had 130K when I traded it with original studs.
Denny |
Originally Posted by rvpuller
(Post 17601048)
Denny |
The only place you will see rust is where you can see them, when I changed the bad manifold gasket on my 4.6 F150 with 122K miles the stud where it went into the head was not rusted just the nut and exposed stud. I even reused 6 of the 8 studs, two broke off when trying to remove the nuts. Every motor I have ever taken apart had rusty exhausts studs. If you change them they will look the same way in a couple of years.
Denny |
Don't play pinata with a hornets nest if you aren't prepared to get stung!
Don't do it !
Some are guaranteed to break off. |
I offer you mixed advice.
1. DONT WORRY ABOUT IT ! I got my v10 E350 4y5m ago and it already had some broken studs on the passenger side. It made some ticking noises when cold but only for 30-45 seconds or so. I’m a very busy man so I just ignored it. Here I am 210,000 miles later with the same van and never fixed it. And yeah it probably has a few more studs missing or loose. I still drive it. 2. JUMP IN ! In your RV, I assume you have more room to work on it. And I assume it wouldn’t be a terrible thing if the project whooped you and caused days or weeks of downtime. Soak them with PB Blaster a few times and then get into the job. Be sure to spend a few hours here on FTE learning what others have learned (learnt? Lol) before you. Keep us posted. |
Originally Posted by Diamnd1
(Post 17604924)
Heres my story...https://www.ford-trucks.com/forums/1...d-project.html |
Did you change those studs?
exhaust
Originally Posted by sddesigns
(Post 17617853)
I did play with the hornets nest deciding to fix the slight ticking sound and go with a new exhaust manifold since we were fixing the already broken ones, but now it doesn't have the Ford studs just the SS bolts that came with the Gibson headers.
