2008 Ford E250 4.6V8 Water leak PLEASE HELP
2 Attachment(s)
Afternoon gents (and ladies?)
i recently purchased my van after owning a express for many years, I liked the design of the ford much more so decided to go with it. However this morning I was driving a long and suddenly overheated, I pulled over and the redo por was empty so I proceeded to fill it. I then noticed all the fluid dropping out from under the truck. I got towed home and proceeded to pull apart the rear engine cover to look for a blown hose or the like. I filled the tank again and noticed water pouring out of a little upspout connected to the Manifold cover. I searched and searched and couldn’t find anything, is there meant to be a hose here or is this some kind of over flow. Thanks in advance. |
Was there nothing on it, I looked at photos of mine, it's a 5.4 and it doesn't have that, it had an aluminum intake too, not plastic which I've heard can warp and leak when overheated. The images I get on the internet have that capped.
Intake Manifold Lobo F150 Pickup E150 E250 Van 2007 2008 New 7L3E9424 |
Yes, everything I find has it capped off, guess thats why mine doesn't have it, they don't use it, but the 4.6 may have an application where it uses it so instead of making one special intake, all have it, they just put a plug on it.
Originally Posted by maples01
(Post 17581192)
Finding a cap could be the issue so i may use a little bit of hose and a 3/4 copper Cap with a hose clamp and see if it works |
I looked and everything was capped, I would love to see what uses it, perhaps the police package.
(Post 17581361)
Who knows?! A friend of mine said it could be something to do with the bigger trucks Triton and up apparently the manifold is the same but he's not a mechanic either so take it with a grain of salt. Anyhow i appreciate your time, i'll throw a cap on it tomorrow AM and see what happens. |
I believe it's a coolant bypass port. If it's about 1" in Dia, this would be the Part # at Advance auto, not sure if that the parts store number or the Dorman number, Part #02250
Originally Posted by Mike1
(Post 17582326)
Thanks for your help guys. |
