Power loss and oil sprayed out dipstick
Hi everyone!
I am new here so tell me if I didn’t post at the right place or if you need other info. I went for a long trip with my Ford 20 ft motorhome 1976 460cid and got issues. I always look for hours on the Internet and under my hood or go to see my mechanic, but this time I am far from home and I am kind of stuck.
Since all those issues happened, we changed the PCV valve and I think it did not change anything because I am pretty sure that a little bit of oil still gets out (I didn’t really get my engine working hard enough again for it to really spray out again as I have a loss of power too quickly. But when the engine is hot, I see some thin smoke coming out from the dipstick when I take it off). Last night we checked the cylinder pressure (I was thinking about rings) and we got: Rear 130 / 115 / 140 / 145 Front 140 / 130 / 120 / 130 All cylinders went directly to around 90 at the first circle, then 100/110 at the second and almost to their max compression at the third cycle. I understood that those results are not indicating something bad. The 115 is not supposed to be badly low, right? I am sure that I did not put more oil than the max on the dipstick but during this long trip I put the max oil level at some point (when I usually try to fill it middle to 3/4 level). So, this morning I dropped the oil (changed the filter also) and put a 5QT in it to check if the dipstick wasn’t wrong. I got the ¾ level on the dipstick. I looked on the internet to know the capacity but I got many different answers from 5 to 7 Qt. How to know the exact capacity? If it is 5Qt could I have overfilled it and damage the engine? I am a little bit lost and I don’t know what to check or to do next! Can you give me some advice please? Thanks for your time guys! Gui and Anna |
Oil blowby from the dipstick tube makes me tend to think it's the EGR plate hole is carbon fouled/plugged up. If you can squeeze the EGR valve (when it's runnin') and she dies, then (possibly) it'll be something different.
It seems like the crankcase isn't getting ventilated well enough and the pressure build up to where she's blowin' oil from any orifice. Pull a coupla plugs.....what do they tell you? And, welcome to FTE. |
Thanks Filthy Beast! I will try that tomorrow.
Spark plugs were looking all the same when I pulled them out for the compression test: a little brownish/orange but nothing bad... |
You have some type of restriction/malfunction in the Crankcase Ventilation System.
You need to either find a/or someone who has a 1976 OWNERS MANUAL to find the correct oil fill capacity. This can also be found in the SERVICE MANUAL. http://cdn.faxonautoliterature.com/A...rdTruckOSP.jpg A cylinder compression test will not give a blow-by indication, only cylinder compression. Just an example- Say the oil return holes in the cylinder head are plugged because of previous poor service, the PCV will not function correctly. The excessive crankcase pressure will push the dipstick out and force oil vapors to the ACL inlet vent. |
