Loard max, and Axle Ratios ? tank you.
ford,2007,5.4L., 4x4 serie: 1FTPX14V27FB49569
watts is maximum charge and Axle Ratios ?
We have Ford 2007,5.4l. , xlt 4x4 series:1FTPX14V27FB49569 Tank-You for you help. Guy Lavoie |
It might help if you post in this forum: https://www.ford-trucks.com/forums/forum24/
The one you posted in is for 2015+ models. |
your on the right forum.......... click on your serial number and you will be directed to a generic page with data from a 2007 model.... there are a few different axle ratios that can give you more or less max weight rating.. the axle ratio (CODE) is listed on the drivers door post, and also a tag bolted on the rear axle pan cover... Get the two digit code and we can give you the ratio.
some common codes
19 – 3.55Non-LS 18 – 3.08 Non-LS H9 – 3.55 LS B6 – 3.73 LS |
