88' F350 460 to 300 six
Hello Everyone,
I picked up an 88' F350 2WD cheap. It has a 460/C6 combo. https://cimg3.ibsrv.net/gimg/www.for...9a10f6ce44.jpg My immediate plans are to swap in 300 six with either an E4OD (updated) or a M5OD (short term). The reason is...I'm averaging 8.6 MPG with the 460 and really don't need that kind of a loss of fuel mileage for everyday driving. Plus, I just always liked the 300 six...and this is coming from a Chevy guy...LOL! Here is a 300/E4OD out of a 94' F150 I picked up from LKQ https://cimg1.ibsrv.net/gimg/www.for...161f347ffd.jpg https://cimg0.ibsrv.net/gimg/www.for...9dcfdf8e70.jpg Here is the "Six" on the stand...getting ready to decrease. So getting into this kind of swap...My question is will the 300 six frame perches work on a F350 frame that came off an F150 frame(donor Truck)? |
Not sure if the perches will work. I suspect you will have to drill some of the holes.
Wouldn't have been easier to swap an E4OD in place of the C6 and maybe go to a 3.31 gear ratio (from a newer 10.5)? |
In quick summary........ the 6's, 302, 351's all share most of the same components including air filter box, etc....the 460 had it's own...... so you may have to address each component.
Originally Posted by bbf385
(Post 17504269)
Wouldn't have been easier to swap an E4OD in place of the C6 and maybe go to a 3.31 gear ratio (from a newer 10.5)? That what I'm hoping for, is just some minor mods if it comes to that. There is really nothing to do to improve upon the fuel mileage of a 460 engine size. Laws of physics come into play when large cylinders of an engine have to be filled and ignited. Nothing wrong with that but I don't think there is anything around it. When I was young, I wanted my trucks to have big engines, lifted and loud. as I get older...I'm going the opposite direction..LOL! |
Originally Posted by Beechkid
(Post 17505109)
On a side note, I did look up a power steering pump for the 460...it does have a different part number then the 6...so that is being addressed. |
(Post 17504269)
Obviously get the correct E4OD.
Yeah, it would require changing out wiring, but not to the same degree as a 4.9 swap. |
Been decreasing the engine and gave a shot of Ford Grey paint. https://cimg9.ibsrv.net/gimg/www.for...c080644f90.jpgAll of a sudden, something jumped out Or I should say, a couple of cracks became exposed. Look at the midway down the block under the 2nd and 5th freeze plugs. Looks like a couple of cracks!
https://cimg4.ibsrv.net/gimg/www.for...43a7c0da3c.jpg Here's one under the 5th freeze plug. https://cimg7.ibsrv.net/gimg/www.for...6b830b7e03.jpg Here's another under the 2nd freeze plug. I filled the block with some water and no leaks. When I was pulling the engine, these cracks were hard to find and didn't see any rust trails like one would find with coolant leaks. So I'm very dumbfounded. My guess is they ran straight water through it without antifreeze and and when a sub-freezing day came the water froze. I really never heard of a 300-6 block cracking but if water freezes, it doesn't matter what you have, it can destroy your engine. So, I might make another trip to the junk yard and grab a short block. Because the cylinder head has no "air tubes" like most other 300-6's do. Dang it! |
Swap
Hi,
I am close to finishing swapping a 4.9l into a 1997 F-350 4x4 that originally had a 5.8l and I kept the original E4OD tranny. I think the frames are similar but not sure but the 4.9l mounts should work and just bolt in mine did. You will need a 4.9l PCM from anything 92' to 94' and if you use an E4OD you will need one that had one of those along with the 4.9l engine. You will more than likely need a o change the underhood wire harness, I had to the pinouts were a little different and the fuel injectors had no power until I made the swap. I would suggest if the truck is already a manual tranny to stick with that as you will have more harness issues to go from manual to auto. Also be aware that after 94' Ford changed the E4OD and moved some electronics from the tranny to the PCM so do not use a 94' PCM with a later tranny, Brian |
Well, it's been a while since the last post but I pressed ahead with the engine swap.
I am still using the engine here with the two cracks...Why? My machinist advised me to "JB" weld the cracks. He stated JB weld is more then enough to secure engine block cracks so as long the engine isn't seeing a hundred pounds of boost. So I went ahead with the ideal to at least try it. First by roughing up the surface area...https://cimg6.ibsrv.net/gimg/www.for...8ce02ef7eb.jpg https://cimg7.ibsrv.net/gimg/www.for...bcd7c70321.jpg Then took some strips of fiberglass and impregnate them with JB weld because fiber reinforce composite is much stronger...and applied it to the block. https://cimg4.ibsrv.net/gimg/www.for...cba10c4c55.jpg https://cimg5.ibsrv.net/gimg/www.for...820cfaf999.jpg Of course potential problems wouldn't be complete without rust int he cylinderhttps://cimg9.ibsrv.net/gimg/www.for...6bbeba37bc.jpg Just took out the piston and honed the cylinder...I'm thinking a rebuildable short block is in order. https://cimg7.ibsrv.net/gimg/www.for...2f2e25176c.jpg https://cimg3.ibsrv.net/gimg/www.for...69db80f918.jpg Long block assembled and ready for install. |
Now it was time to remove the 460/C6 combo.https://cimg6.ibsrv.net/gimg/www.for...1314ff8985.jpg
https://cimg8.ibsrv.net/gimg/www.for...bb0baad450.jpg https://cimg9.ibsrv.net/gimg/www.for...efdb7e92f1.jpg The harness wasn't hard at all for this particular one just came unplugged from the engine bay harness. Not like that on all of them. |
How does the engine run? Happy with the swap?
Originally Posted by BWD444
(Post 17546512)
Hi,
It's been a while since I posted but here are the updates.
The 460 was sold off to a Craigslist junkie who used it to empower his 1970's Ford. He's loving it. Now that the 460 was removed, I got to work on frame mount modifications. Had to clear the rud that acted as the protective coating. https://cimg6.ibsrv.net/gimg/www.for...d8f41f031a.jpg The 460 frame mounts were mounted behind the crossmember. The 300-6's mounts will be forward, right on the crossmember. The driver side 460 mount was riveted while the passenger side mount was bolted. I guess the driver side mount was riveted due to the fact to handle the torque of the engine during the life of the truck. So, https://cimg5.ibsrv.net/gimg/www.for...bdfb3c3a76.jpg I left it and removed the passenger side mount. The frame mount for the 300-6 was installed on the drivers side as you can see. Here are the frame mounts for the 300'6, got em' from a 94 F150...and they pretty much bolted on. Had to drill ONE hole on the driver's side. https://cimg4.ibsrv.net/gimg/www.for...6550312c5b.jpg The engine was fit tested and everything lined up great, like it was factory. So on to mating the engine to mating the engine and trans and installing them. https://cimg7.ibsrv.net/gimg/www.for...dafa67e3b9.jpg https://cimg1.ibsrv.net/gimg/www.for...98f1b15e49.jpg https://cimg3.ibsrv.net/gimg/www.for...ca652e7bb0.jpg BTW, the E4OD was rebuilt and updated. It is a 94' transmission so it lacked the updated pump, Overdrive carrier bearing and misc small stuff. Being that it came behind a 300-6 out of an F-150, it lacked the number of clutches vs a bigger V8. I took no pictures but the E4OD was over hauled with updated pump, carrier bearing, additional clutches, steel planetarys vs aluminum and a Trango "Tugger Kit". |
