2016F150XLT (<1yr) LOUD undercarriage rattle (pt2: 6 sound files)
6 Attachment(s)
Rattle is totally random on <16K new F150 truck. Hard to recreate, loud when it happens (~2-5 second).
Happens within 2 miles after prolonged parking (overnight/work). 6 sound files recorded with cell phone attached below. I (and the dealership techs) have looked under the truck, no apparent loose parts, sounds seems internal to engine/transmission. Was already in service for a week, no luck. Will take it in one more time to dealership that sold it, and a second time to a dealership nearby. If not solved after that, I'm thinking about opening a lemon case with Ford. Advice on noise source/how to proceed welcome. More details in the thread "2016 F150 XLT (< 1 yr old) rattle in undercarriage" Peace and Thanks, CFDer01 |
Good Morning CFDer01,
I am new to the forum due to this same issue. I have a 2017 XLT 3.5 Eco. your audio files represent the exact noise my truck is creating during the same time. did you/dealer ever figure out the issue? any advice would be much appreciated! thanks |
Sounds like the same noise on my Dad's RAM, turned out to be a deflector plate on the driveshaft where it went into the rear end, the tack welds had broke.
I didn't check this thread for a long time because I thought nobody would answer ... thank you jd50 and 3greezy for you comments.
I spoke with the manager at the second dealership that kept the truck for a week. They went over the recording with other techs but could not recreate the noise. They drove it out morning/evening for a week but it was quiet. They also took a good look at the front hub. The service manager over there told me he thinks it's something to do with a vacuum leak in the 4x4 system .... it got a little to technical for me to understand. The weird thing is that since that service, the noise has been quiet. It has previously been active for 2 months, then quiet for 4, then again active for 2 regardless of my using 4x4. The 2 bottom lines that I got was: 1. Until they recreate it, they can only guess at the cause. 2. The service manager of the dealership that sold me the truck and the 2nd dealership that did a 2nd check both told me to start a case with the Ford hotline. They said they would recommend extending the warranty for a couple of years ... that's all they could do. Note that another thread has appeared: "2016 front end vibration and noise" where they report the similar symptoms with their truck. I may post there and direct them to these recordings. 3greezy hope you get this message ..... Thx, CFDer01 |
I'm putting my money on a vacuum leak....most likely your check valve right before your IWE solenoid.
Mike |
Originally Posted by Grdsman2025
(Post 17633350)
Mike Grdsman, thx for a specific pointer. I'll discuss it with the service manager at the dealership and see what he says. Unfortunately I just drive the thing and do routine maintenance but don't know much of the engineering of the wheel/suspension elements. Thanks again. |
yeah it sounds like the IWE partially engaging. Mind did it, but it was every time you stepped on the gas.
