AOD Max Tow Rating.
Does any one have any idea what the Maximum rated towing capacity was for the AOD ? This is irrespective of chassis, engine or rear gear ratio.
Naturally I would assume it would be in the E or F350/250 with the AOD and 351W/5.8L. Thanks. |
I don't know what the actual spec is but consider this..
In these trucks the AOD was never factory installed in anything bigger than an F150 and never behind any engine other than the 300 I6 or the 5.0 V8. |
Originally Posted by Conanski
(Post 17457388)
In these trucks the AOD was never factory installed in anything bigger than an F150 and never behind any engine other than the 300 I6 or the 5.0 V8. It was offered behind the the 4.9 302 and 351W in the F150-350 and the E150-250. Hell it was behind the 351W in the panthers for police and the tow package cars that had 5000 lbs towing capacity. Thanks for commenting but not what I'm looking for. |
Then consider this: towing capacities provided in the owner manual are differentiated by manual and automatic transmissions. All automatic transmissions available for a specific application are rated the same.
Originally Posted by mrollings53
(Post 17457413)
So no all auto trans are not automatically rated for same GCWR. If what your saying was the case then the there would be no tow packages on vehicles. Thanks for responding but I'm looking for actual numbers not conjecture. We know until 91 there was only the AOD for a 4 speed auto so this will be for vehicles 91 and older. |
Originally Posted by matthewq4b
(Post 17457405)
Ya not quite true.
(Post 17457405)
(Post 17457436)
(Post 17457470)
It did appear in the late '80s f250LD behind the 2 smaller motors but not the 351.
Yes but that isn't a truck. If you find one in a 351 truck it isn't factory. The AOD was used behind the 351W in trucks pretty much all automatic late 80's Broncos had the AOD behind 4.9 302 and 351 last time I checked that was a truck. It was also used in the E series behind the 351W And there is no way the 275 Ftlbs is correct the 302 put out more torque than that in some applications with the AOD let alone late 80's EFI 351's that put out over 300 Ftlbs. Maybe you were looking at max HP instead of torque as that would make more sense.. The E40D slipped my mind and it was introduced in 89. The max tow capacity of the 351W AOD in the Bronco's was 7800 LBS on a 8.8 Rear end no less. And again NONE of that answers the question. Like I said I'm looking for actual numbers NOT conjecture.... |
(Post 17457615)
....And again NONE of that answers the question. Like I said I'm looking for actual numbers NOT conjecture....
(Post 17457367)
.... irrespective of chassis, engine or rear gear ratio....
(Post 17457436)
Towing capacities are rated as per the GCWR for that particular vehicles set up. Each Engine, suspension capacity, Transmission and ancillary items Trans PS cooler ect dictate the GCWR....
8347.0 lbs.
He needs that in kilos. LOL}>
Originally Posted by Nothing Special
(Post 17457798)
Yes, but when you say
you are eliminating the possibility of actual numbers. You apparently know this because in another post you say Seriously ? Rear axel ratio factors in to max tow rating. As does suspension and other items. Remove that from equation so it is not a limiting factor. Not sure what is so difficult to understand about that... it's not rocket science.
(Post 17457798)
So how can anyone give you the answer you're looking for?
Quantum chromodynamics. |
Originally Posted by GoinBoarding
(Post 17457896)
8347.0 lbs.
I assume that was an F250 application? |
Originally Posted by 88XLTLariat
(Post 17457928)
Metric should have stayed on the other side of the pond. |
The *factory* AOD may well be limited to 275ft lbs, not the AO-Dominator or raptor or whatever made elsewhere.
but but but you say, so and so builds them to handle 600hp, while this may be true, the tranny rating is based on the lock down torque, meaning, the output shaft is welded to the side of an aircraft carrier. what can you input before it breaks internally. A 600hp engine, unless you found a 5000rpm stall converter, will not be imparting the torque at start. Once rolling, the resistance of the vehicle to prevent acceleration is not as great such that at any moment, future hp/torque is not a large gap from current hp torque when the engineers perform the integral math. If there was an AOD behind a 351 in the 80's, and Im not saying there was or was not, before EFI, the 351 was a weak 150hp sister making 260-280ftlb. This was on par-ish with the bowtie 350 of the same time The being said, IIRC the largest tow rating I ever saw for an AOD was 7600lb (or was it 7200?) with a 302/355 rear or 8600 (was it 8200?) with a 302 4.10 rear. not sure why you want to know and what you have in mind, but towing big things requires big parts. The C6/E4OD were the HD trannys vs the C4/AOD just like chevy used the 400/4L80 vs the 350/700R4 |
