Monitor TPMS using Torque Pro
1 Attachment(s)
I posted this before but it got buried in someone else's bloated thread so I'm starting a fresh one of my own.
I created a page in Torque Pro just for monitoring TPMS. I manually added these extended PIDs onto a generic 7" tablet that connects via Bluetooth to an OBD2 reader. Here are the PIDs you'll need: PID LONG NAME ID I used for display 222813 TPMS DRIVERS FRONT PRESSURE LF TP 222814 TPMS PASSENGER FRONT PRESSURE RF TP 222815 TPMS PASSENGER REAR PRESSURE RR TP 222816 TPMS DRIVERS REAR PRESSURE LR TP 7" tablet: OBD2 reader: :-drink |
These 4 pids are in the Plugin I built that has all the known PIDs..
see this topic https://www.ford-trucks.com/forums/1...nded-pids.html |
Originally Posted by sdetweil
(Post 17435209)
see this topic https://www.ford-trucks.com/forums/1...nded-pids.html That just links to a 51 page thread. Thanks |
Originally Posted by BINARY
(Post 17436326)
Got link to the exact post?
That just links to a 51 page thread. Thanks this last post has a link to the latest plugin. https://www.ford-trucks.com/forums/1...l#post17433541 this post has the general installation/setup instructions https://www.ford-trucks.com/forums/1...l#post14573134 |
(Post 17436347)
https://www.ford-trucks.com/forums/1...l#post17433541 this post has the general installation/setup instructions https://www.ford-trucks.com/forums/1...l#post14573134 :-drink |
i'd love TPMS through my TP setup on my truck. i have an 04 dually though. does this only work on trucks that have factory sensors? i've on and off been looking for a decent yet not insanely expensive setup to monitor all 6 tires on my dually. didn't know TP was an option, so that takes care of needing any extra screens or anything for an aftermarket system. wonder if i could use OEM sensors (i think the newer dually's come with TPMS?)
Pretty sure your truck computer only reads the oem senors because it was programmed for that.
BINARY,
Could you post a pic of how you have your tab set up in your truck? I just can't seem to find an install that I like yet. |
Originally Posted by ufvj217
(Post 17437476)
(I have a dually too).. I use the truck systems tpms system with stem mounted sensors.. I got mine here https://www.vulcantire.com/tpms_tst.htm I have two monitors, one for 5th wheel and one for my car hauler.. hate reprogramming |
(Post 17441213)
the dually doesn't have the sensor receiver hardware either, so it won't work.
(Post 17441286)
nice, i was looking at those stem mounted ones the other night, they seem to be pretty popular.
and the flow thru type on my 5th wheel (I take them off to adjust the pressure as they fill so darned slow).. |
Ill have to do this later
1 Attachment(s)
Originally Posted by bkuuz1
(Post 17439573)
BINARY,
Could you post a pic of how you have your tab set up in your truck? I just can't seem to find an install that I like yet. You can see 2 on the dash, one for driver one for passenger, for our iPhones, then I use this mount which slides directly into the CD player slot. Who uses CDs anymore? I also have a 7" Garmin RV GPS that uses this mount. It sticks out about 4" or so towards the driver so it's easier to reach than the stereo. Well, for me anyway, but I drive with the seat all the way back. :-X22 |
(Post 17445868)
I use magnetic mounts for all my electronics.
You can see 2 on the dash, one for driver one for passenger, for our iPhones, then I use this mount https://www.amazon.com/gp/product/B0...8&psc=1http:// which slides directly into the CD player slot. Who uses CDs anymore? I also have a 7" Garmin RV GPS that uses this mount. It sticks out about 4" or so towards the driver so it's easier to reach than the stereo. Well, for me anyway, but I drive with the seat all the way back. :-X22 I so want to figure out a way to install the OEM receiver for the dually. I really dont want another screen... I looked at this one. Smart TPMS But here is the response I got about landscape view vs portrait. Just in portrait mode and I have submitted your request to the designers about the App Disconnect. I like that feature as well. On our TM-77 model has the 3 positions. Thank you for the suggestions!!!! I need to follow up with them. |
(Post 17445868)
