adding an "air" oil cooler
currently looking for an "air" oil cooler for my 6.4l
anyone have any recommendations AMAZON has a few complete kits with thread on hoses. I currently have an oil bypass filter and am thinking of putting the cooler on the filters return line. |
so this is what I am going with.
theres room in the mouth of the bumper and the top of the cooler will not be in line with the inter-cooler I have a bypass filter that runs from the oil filter cap , to the filter, then back to the oil fill cap.....so I plan to put the cooler in line with that. later, might by the adapter to relocate the engine mounted filter which would result in all the oil flow going thru the cooler...not just the by pass oil flo. |
how has this turned out? Worth it?
BPD has A-O cooler you can "add" on top of the relocation C-O cooler&filter kit they have.. but havent really seen one for the 6.4 that eliminates the c-o cooler like they do with the 6.0's.. while i dont have a 6.4 i can tell you im pretty happy with the cooler on my 6.0 from them.. i know from working on my neighbors 6.4 yall have a ton of room behind the grill you could probably even mount the same cooler used in the 6.0 kit infront of the condenser with a little modification and get a custom hose made to connect to the 6.4 relocation kit.
I bought the cooler and its on my someday list...someday when its not 10 degrees outside.
