Originally Posted by Scndsin
(Post 18494659)
Is the trans bolted down & you're mating it with the hoist?
i marked the hole for the TC drain plug on the flex plate and used the matching one on the new flex plate so? |
The TC has studs, right, not bolts?
I'll be honest, I prefer to mount the engine & bring the trans to it. It's easier (for me) to move around & line up. |
(Post 18494708)
pic of when I put the engine in the truck the first time note the chain rig on the hoist bar my micky mouse way to get it out of the van the distributor was hitting on the bottom of that bar the bolt ripped the fire wall insulation out of the underside of the dash,the bar was level to the ground.
you can just make out the R&P at the drop down in the oil pan sump https://cimg1.ibsrv.net/gimg/www.for...11dc6759bd.jpg |
If you have doubts about whether the TC fits the flex plate, can you try test fitting just the TC t the FP? I mean, pull the TC off the trans and hold it up against the flex plate just to see if the studs would line up with the holes in the FP, and have the TC nose fitting into the pilot bearing. At least you can verify that they DO fit.
That would a good third way to check it like I said I put the new one over the old and they matched the I reversed them so? |
Cold? I thought all of Cali stayed at 80* year round. :rolleyes:
No heat in your shop? |
(Post 18495638)
No heat in your shop? I am going to try rotating the engine to see the other end of the flex plate/TC |
Everything bolted up square ?
(Post 18497220)
i was with my grandson most of the day way more important than an old truck |
https://cimg7.ibsrv.net/gimg/www.for...eaadcc224.jpeg This was a few weeks ago |
Without a doubt in re grand kids.
You should be able to line up the studs on the TC, push the block/trans together. If you draw them tight & square, there should still be a bit fore/aft movement between the TC/Flex plate & the nuts draw the TC forward to the flex. |
(Post 18497502)
Originally Posted by schoo
(Post 18498188)
going to check it again this morning I’m not happy with the way theTC is going in https://cimg7.ibsrv.net/gimg/www.for...31ce05dc83.jpg |
Hell the old saying measure twice I need to measure once now that’s just getting old |
Yea, automatics don't use any pilot bearing.
Thanks this must have happened when I swapped cranks it’s not funny when things snow ball out from one thing too another |
That'll do it. Hope you didn't damage the front pump trying to push the TC into that pilot bearing.
Don’t want to think about it |
https://cimg0.ibsrv.net/gimg/www.for...6d0a4a04c.jpeg Serpentine system is in mostly https://cimg9.ibsrv.net/gimg/www.for...66c2c84ec.jpeg I’m not very good with the rtv |
Looking good regardless of such minor issues.
Keep the faith & you'll get there. |
Way to go, now it gets exciting! Best of luck, keep us posted
https://cimg7.ibsrv.net/gimg/www.for...e3feac563.jpeg This was way before I had much done about 4years ago l have to have pic it would be too boring Thanks guys. I need to send the dizzy gear back wrong with that one yea when ever I have a 50/50 chance I get it wrong. I measured it before I got the gear off only thing you can’t measure it until after it’s off it has a step up in the shaft |
Nice, looks like you have came a long ways!
Ok the upper manifold is in, I primed the oil system again and then hit the starter it spins so next put in the plugs and distributor when I get it together https://cimg7.ibsrv.net/gimg/www.for...9caf06ada.jpeg P |
Cool Roy, It looks like your making progress everyday!
https://cimg5.ibsrv.net/gimg/www.for...712d434c6.jpeg This is 1000gt |
https://cimg8.ibsrv.net/gimg/www.for...cdb71e62e.jpeg I can’t see any difference between 1500 and 2000 this is 2 |
That's gorgeous but how yah gonna seal it? Zoops?
(Post 18509875)
https://cimg8.ibsrv.net/gimg/www.for...4dbec31722.jpg 2 gears and both are wrong I ordered a new distributor man 😪 |
https://cimg9.ibsrv.net/gimg/www.for...82424dfcc.jpeg Installed the radiator, AC condenser and trans oil cooler got too love tight spaces on these trucks |
Ok it runs but I have a leak at the thermostat houseing and boy do the Chinese distributors look bad going to send that back |
Good job! Pat yourself on the back.
I just hope this dizzy hasn’t trashed the cam gear it wabbles bad I can’t get lucky on anything the stuff sold now days |
https://cimg7.ibsrv.net/gimg/www.for...1363160415.jpg
this engine was shipped to Europe I am glad I changed out |
What is that & what on earth is the story?
And what's up with the 49? Your original drive train... DOH (edit) |
Sold the engine and crash box for $200 and the ships stuff over there that was my truck it’s what was a truck before it got too he a hot rod |
