Originally Posted by Beanscoot
(Post 18336547)
I was aware that the E7TE heads were considered much better than the late 70s to mid 80s heads (D8OE etc.) but are they actually as good as, or better than the C9OE heads? They do have the advantage of hardened seats, and pedestal rocker arms.
Now are you comparing ported E7's to ported GT40's? Or are you comparing ported E7's to stock GT40's? Comparing a ported head to a non ported one is like comparing apples to oranges. If a person is on a budget porting the stock heads is the way to go. But if there is a little more budget starting with a better pair of heads is the way to go. You will always see bigger gains starting with better heads. I'm doing it both ways. I'm porting my stock heads on my 96 351W and I'm porting a set of GT40's for my 89 351W. No matter what heads you are using they can always be improved with some porting.
https://cimg7.ibsrv.net/gimg/www.for...f71f52298.jpeg Heads I don’t?? Block is at machine shop hope I get by cheap |
Here’s a pic https://cimg4.ibsrv.net/gimg/www.for...3dff4da91f.jpg Dave (Scndsin)can tell me a little about the engine paint job you did was the engine on the stand or in parts when you painted |
Nice truck!
It's usually easier to paint the parts when they're apart, as you can get at them from all angles for a more thorough coverage. Have them paint the block before installing new brass freeze plugs, so they really stand out, if you care about this little detail. When I had my heads rebuilt, I also had them remove the AIR bumps, but the tech who did it took so long that they charged so much for that little mod that even the head machinist said I probably could have gotten better aftermarket heads. And I ended up with stock heads that just had the bumps removed. So it depends on who does the work. |
I’ll see happens with the block and crank if can use my pistons it frees up some $$ And thanks my same thoughts but never took the time to paint an engine |
Man that's a sweet truck.
Did all the parts separate with lots of cardboard, blue tape & plugs. Block was on the stand. All those "all over" paint jobs on the tee-vee shows drive me nuts. Things need to come apart from time-to-time & big chunks of paint breaking off bolt heads & mating surfaces, seams, etc. get everywhere & in everything. This pic is actually from before my build with just some clean up & detailing. I never had a full dress pic after the rebuild till it was back in. https://cimg5.ibsrv.net/gimg/www.for...81bbba58a6.jpg |
Thanks Dave, pictures are always good |
What about m6250-e303 cam with GT40 Heads will these mate up to my efi and pcm |
My block came out good just cleaned and honed, crank getting turned |
Conaski sez the alphabet cams do not play nice with speed density computers.
He might step in and recommend something that would work with your trans & gear ratio, or you could give a mfg's tech line a shot. |
Ok still looking |
Ok I ordered some GT40 Heads so on to the cam? Money is getting a little thinner and need a lot of parts |
Supposedly the B303 was designed for the SD EFI systems. But I've run them with a carb and they have a nasty lope at idle. Sounds good though }>
I really don’t want the lope rather get mpg, Dave how do you like the cam your using |
