Originally Posted by Tim Young
(Post 18544230)
I think David is asking about the harmonic balancer, does it have a 0 degree mark at TDC and the degrees BTDC on one side and degrees ATDC on the other? It looks to me as though it just has the degrees BTDC and 0 degrees TDC.
https://cimg3.ibsrv.net/gimg/www.for...f9e8219e82.jpg Started down I just felt it |
(Post 18544230)
Yes. I'm thinking I see nothing but degrees after TDC. There are things called timing tape, but Henry Help Us, if you can find one for a sbf. |
OK, my bad. Looked at a balancer on the shelf & yours shows before degrees & no after degrees.
The pointer lines up with the first zero mark when you find for sure TDC? |
Originally Posted by Scndsin
(Post 18544983)
The pointer lines up with the first zero mark when you find for sure TDC? the engine started on the third try of the key after assembly it has never been off by very much |
Then you should be able to pull the spout, loosen the hold-down & get 10* (second 0, second red mark to the right)
Unless the cap is hitting something. The only other issue you might be having is that 8 inches of vacuum could be some heavy leak. |
(Post 18545097)
Unless the cap is hitting something. The only other issue you might be having is that 8 inches of vacuum could be some heavy leak. the only vac line I have doubts about is the egr from the solenoid to the unit will it run if pull that line |
You can disconnect the vacuum line at the EGR valve and plug it. It will have no effect for your purposes at this time.
8 inches of vacuum is way low. Vacuum that low would most commonly indicate a manifold leak. Is the PCV valved line made to the tapped opening on the the rear of the upper intake? I know this connection opening is out of sight, maybe out of mind. |
Originally Posted by diggerrigger
(Post 18547312)
I drove it up to town twice today first time I tried it at 12°-15° I had to stop and advance it up to 20°+ just to get up the hills. It it heats up to the fan comes when not moving but driving it cools down to 190 or so, when I turned it off I checked the thermostat housing with my gauge and it read 197 just after shutdown. |
Well besides the motor, everything else is working ok?
I would like to see a photo of your truck! |
197* is good. 20* I guess will have to be lived with for now.
Are your IAC, throttle body, gaskets new? Are all the extra ports on the vaccume tree capped? This thing doesn't have a power brake booster does it? What intake to head gasket did you use? |
https://cimg6.ibsrv.net/gimg/www.for...ea3e654d5.jpeg Ford had the gas tank in the cab mine (Chevy van Fi tank)is in the rear behind the Chevy rear end, gas cap is jag
(Post 18547494)
There are lots of truck on FTE that are sooooo much better than this truck check out some of them on the 48-56 forums |
(Post 18547512)
Are your IAC, throttle body, gaskets new? Are all the extra ports on the vaccume tree capped? This thing doesn't have a power brake booster does it? What intake to head gasket did you use? gasket at throttle body is new IAC was not messed with The tree is caped where no hose are ill check out the lower intake manifold also yes I have a vac booster for brakes and I have had some trouble with brake fluid leaks at master (Chinese) |
Thanks for the update!
