TPS Voltage
I read somewhere that you can test the TPS voltage. How is it done and what should you adjust it to on a 1989 5.0?
TPS Voltage
Hi,
My truck is carbed so I basing this on my Mustang and Town Car. With the key on engine off, probe the green wire with a digital meter, grounding the black probe. You're looking for less than 1 volt, some where around .95 or so. There is a small range of adjustment by loosening the two screws and turning the sensor. Good luck. Rodger |
TPS Voltage
VKaro45 - Thanks!
TPS Voltage
