Extra Battery Alternative's with Torklift's HiddenPower
https://cimg9.ibsrv.net/gimg/www.for...c58f5c17c4.png
The Torklift International HiddenPower is a specially designed and convenient auxiliary under vehicle battery mount for all types of Group 24, 27 and 31 twelve volt batteries such as lead acid, AGM, sealed, gel cell etc. Engineered as no drill installations with quick disconnect electrical connectors, the system quickly attaches to the truck’s frame under your truck. The HiddenPower allows you to have extra battery power in your RV significantly extending the time you can run on your 12-volt systems. By adding an extra battery that is tied into your truck's electrical charging system, keep the battery charged and healthy and always ready for RVing with little to no maintenance. The HiddenPower auxiliary battery is designed to also maintain its charge while RVing by becoming an extension of your RV's battery when your RV is plugged into your truck and will recharge via your RV's existing solar panels, generator, converter etc. at the same rate that your RV's batteries charge. The HiddenPower auxiliary battery allows you to camp using battery power without draining your vehicle’s battery when coupled with the HiddenPower Wire Harness (sold separately). The HiddenPower under vehicle auxiliary mount comes with Torklift International's Legendary Lifetime Warranty† and is proudly made in the USA. † polymer battery box carries 1 year warranty * Wire Harness carries a 90-day warranty HiddenPower Features
ACTUAL PRODUCT COLOR IS BLACK. SHOWN IN YELLOW FOR CONTRAST HiddenPower Wire Harness Features (sold separately)
https://cimg1.ibsrv.net/gimg/www.for...dfaf4791db.png Click here for more information on Torklift's HiddenPower. |
