95 Bronco MAF big block swap issues
Hi everyone I have just completed a 460 maf swap in my 95 Bronco. I reused all the factory wiring and adapted it to the big block using a way1 computer. My question is, is I've tuned in the engines fuel pressure and timing with the mass airflow sensor plugged in the truck almost acts like its starving for fuel but once it's on plugged it runs great can anyone tell me anywhere to look I pulled codes in the only code that appeared was an air charge temperature sensor which I replaced and cleared the code and still have the issue
That PCM was built for a truck with 19lb injectors but your 460 has 24lb injectors on it so you need a tuner.
I ordered a 80mm Mass Air housing calibrated for 24 pound injectors to compensate for that. Brian at 5 ology racing says that there should be no reason that the 302 computer should not run the 460 on a base tune in that having it tuned is only to pull every ounce of power out of it
Originally Posted by 95Bronco460
(Post 17355643)
Yeah I was testing the mass airflow sensor earlier and everything tested out fine so we're thinking there's an issue with my PCM. If what you're saying is that I can't use it to the effect that I'm trying to how exactly are people using way one computers to swap in Big Blocks and what mass air meter housing and mass air flow sensor would I use with a WAY1 comp
(Post 17356118)
so how is brian at fiveology building the kits with the way1 ecu and selling them and peipke arnt having to tune them?? everyine has a different opinio. it seems.. personally ive seen my BB run great at cam break in but for some reason there an issue now.. i think its going to be a sensor or the ecu. but i guess ill find out one way or another
(Post 17356250)
so how is brian at fiveology building the kits with the way1 ecu and selling them and people arnt having to tune them??
no its in a DD/Off-roaded bronco. the kits he sells are to convert BB F-series to MAF, and its a layover harness with a selected MAF housing size calibrated to your choice of injectors and uses a WAY1 ecu to run it all along with repinning 4 injector wires to match the 460s firing order and he told me hes never had a customer have to tune it to run right and that tuning qill just net every horse available. when i broke my cam in the motor ran smooth as a babies bottom
(Post 17356265)
(Post 17356265)
https://cimg4.ibsrv.net/gimg/www.for...151fcd0957.jpg
yes its a flat tappet. its not much more then the factory cam. we've also verified the cam isnt flat. |
so what did Brian say about the problem.
Originally Posted by Redark1
(Post 17356996)
https://cimg2.ibsrv.net/gimg/www.for...883c985688.jpg |
just to ask a stupid question are you getting a CEL or are there any codes. you using a ACT sensor. did you put in a new ECT sensor.
Yes all sensors are new other than the idle air control valve the mass airflow sensor and the canister purge valve. Also the computer was about 5 years old
