Swapping a F350 460 7.5L into a F250 460. 7.5L
Hi everyone,
I'm wanting to put a new engine in my 1988 Ford F250 that has a 460 7.5L engine it in. I do a lot of traveling over Snoqualmie Pass and I drive horses trailers a lot. So I was looking into a newer year engine that would have a little more power but that gets me better gas mileage then the engine I have now. So I'm wonder if I could but in like a 1990's F350 engine into my 1988 f250 and will it be compatible with all the wiring and harness. and wanting to get other people's opinion on if I should put the f350 460 in or just put a new f250 460 engine into my truck. Thank you. |
No difference between F-250 and F-350 engines.
There will be wiring differences between some years, but I don't know details on that. Also some changes in the heads / intakes (but that might be only carb vs EFI and I'd guess your '88 is new enough to have EFI) |
I'm knee deep in my first 460 build. I came across something recently that might interest you. I'm swapping an '89 for a '90. I didn't think there would be any differences because they are the same generation f series. the fuel rails on my '89 connect up by cylinder 1 where as the '90's fuel rail connects back above the bell housing. Not incredibly important but there are some differences even between one year.
Originally Posted by 1979brandon
(Post 17344150)
my bad you're right. I meant 5.
