expedition el limited won't crank
2007 Ford Expedition EL Limited
shows traction light shows wrench flashing security light Power good, all lights, power lift gate, windows etc. work Key turns all the way and all you get is a single click from the starter relay in Master junction control box |
Did you try starting it in neutral? Could just be a bad starter. You would need to test each terminal on the starter for power while attempting to crank it before you can diagnose it any further.
...flashing security light... |
