2004 f350 wheel bearing part #
I have 156k on my truck and I want to install new wheel bearings. I've been looking for the best prices and it seems rock auto and Amazon are about equal. Problem is they list ten different options and if like the correct part numbers if possible? I'm looking at timken or SKF if possible, also part # on the four mounting studs and nuts OEM or aftermarket?
2004 f350 srw 4wd with fine thread lug studs |
Every Timken hub assembly I have bought at Rock auto came with 4 studs and a yellow o ring
Yes my originals have 156k, they spin nice and smooth and have no play as far as I can tell. I grease them once a year through the ABS hole with a dino grease made for wheel bearings
