P1273 Code - Ran all the normal tests
Starting a new thread as not to be confused with my HPOP saga.
So I got an IDM code and then after running AE buzz test got a P1273 (#3 cylinder high low open). Ohm'd out the 42 Pin - got 3 across the board. Only test 42 pin from valve cover to injectors. Double checked UVHC Swapped solenionds Swapped injectors Did ford wiggle test. Ran Injector buzz between all those steps and still get P1273. What's the next step? Ohm from IDM to 42pin? May actually be a bad IDM? Thanks all! |
Well, removed and reinstalled the solenoid again and did another look over all the harness and didn't see anything again, so i just taped some areas up that were exposed and now the code is gone.
Moved the harness around a bunch more times in various ways and ran the buzz test and nothing. So moral of the story, sometimes you just gotta cross your fingers and hope it doesn't come back. |
Are any of the wires coming from the 42 pin connector to the IDM rubbing on the valve cover?
Here is a link to the 42 pin connector breakdown
https://www.ford-trucks.com/forums/a...4&d=1397068072 https://www.ford-trucks.com/forums/attachment.php?attachmentid=95774&d=1397068072 |
They was about 2" of exposed wires there but they all visually checked out cause i really looked at that part. I wrapped in a generous amount of elec tape.
Exposed as in insulation had rubbed off and the wires could have been grounding on the VC?
Exposed as not in wire loom. Insulation appeared to all check out
#1 injector and #3 injector, and the code didn't follow the solenoid
ok, I don't really think your symptoms are pointing at a IDM failure yet. If you had any IDM codes you should see a P1316.
From the 7.3L quick reference guide: P1316 - "IDM Codes Detected" (7.3L) IDM Codes are stored in memory in the IDM itself. The P1316 DTC is an indication that there are stored IDM Codes that need to be retrieved and/or cleared. Executing a "Clear Codes" will clear both PCM and IDM codes...DO NOT CLEAR CODES until you have retrieved and reviewed the codes stored in the IDM. Note: IDM Codes are stored in memory. If you have a code indicating a fault, but there is no drivability problem, the fault may not currently exist. After taking note of the codes, execute a "Clear Codes". At this time you should be able to re-run the above tests with no IDM codes generated. If one or more IDM codes are still present after the "Clear Codes" command has been successfully executed and the above tests performed again, the fault still exists and further examination is necessary. |
Check out Post #6 here by Mueckster. It explains what wires you need to test fro the 1273 High _ Low open fault.
https://www.ford-trucks.com/forums/8...-inj-code.html |
Originally Posted by white Buffalo
(Post 17284051)
Hmmm, that is a good question. I'm not sure. But I would guess that they would be stored until they are cleared. But I do not know. Sorry.....
(Post 17489255)
I would like to hear what you find with your long start, I'm chasing one and can't seem to get it.
