Good evening all. Does anyone here have a suggestion on a chrome brake booster/mc combo? My proportioning valve is below the cab on drivers side. Although it was originally located on the steering gear box. inline tube sent me the lines that terminate under the cab at a prop valve there. I purchased a adjustable prop valve from speedway it is a cpp. I'm confident it will work fine, now I cannot find a booster/mc combo (chrome) I hope someone here can be of some help. Thank you for taking the time to read this.
Here is a chrome 7" double diaphragm booster:
Universal 7" Dual Diaphragm Booster Chrome - Pirate Jack And here is a matching 'corvette style' master cylinder: MC1321ACHFT - GM Universal Aluminum Chrome Master Cylinder, - Pirate Jack On the MC, make sure you get a disc/disc or disc/drum unit to match your setup. |
Originally Posted by monkey-1
(Post 17735881)
Universal 7" Dual Diaphragm Booster Chrome - Pirate Jack And here is a matching 'corvette style' master cylinder: MC1321ACHFT - GM Universal Aluminum Chrome Master Cylinder, - Pirate Jack On the MC, make sure you get a disc/disc or disc/drum unit to match your setup. https://cimg2.ibsrv.net/gimg/www.for...819c562507.jpg and my part # that was shipped matched the part # in there catalog for a 74 f100 2wd short bed. Well for some reason I received a brake line kit for a 73. https://cimg0.ibsrv.net/gimg/www.for...010faba978.png I don't believe I'm the only one that has received the wrong brake line kit. This in turn is where all my confusion is coming in to play, I don't have enough knowledge of brake systems to know exactly what I can and cannot make work. I have emailed LMC with this issue and have yet to get any response. I'll keep yall posted as to what information I may get. |
on a different note, How should I go about painting these hood hinges? Does the yellow need to be removed before I paint or can they simply be cleaned with some metal prep?
https://cimg3.ibsrv.net/gimg/www.for...63939dd9ec.png |
got most of the dash finished today.
https://cimg7.ibsrv.net/gimg/www.for...8648767a67.png https://cimg8.ibsrv.net/gimg/www.for...efd1ef249c.png https://cimg0.ibsrv.net/gimg/www.for...544974edb3.png https://cimg3.ibsrv.net/gimg/www.for...b18102649f.png https://cimg4.ibsrv.net/gimg/www.for...d62befb04b.png |
https://cimg7.ibsrv.net/gimg/www.for...dfca7ce641.png
https://cimg1.ibsrv.net/gimg/www.for...274700193a.png https://cimg2.ibsrv.net/gimg/www.for...588a6313f1.png Got the trans cooler all mocked up and brackets made, now to take em apart sand blast and paint. |
Wow!
Awesome looking engine! Have enjoyed following your work! Regards, Chris |
Thank you.
Does anyone here have a suggestion on classic insurance?
https://cimg2.ibsrv.net/gimg/www.for...149e1cceae.jpgWorking on new lower cross memeber.
https://cimg4.ibsrv.net/gimg/www.for...f270322e1e.jpg https://cimg5.ibsrv.net/gimg/www.for...1ede69120a.jpgPassenger side clearance is great. https://cimg7.ibsrv.net/gimg/www.for...af9b6a71d4.jpgDriver side. Not so much. https://cimg8.ibsrv.net/gimg/www.for...b853c4c572.jpg https://cimg0.ibsrv.net/gimg/www.for...5123ad837e.jpgBolted flange down in an attempt not to warp it. |
Originally Posted by MrQuick
(Post 17253439)
https://cimg4.ibsrv.net/gimg/www.for...7c5f031b29.jpgSpring is nearly touching i beam. I am assuming this cant be good.
You can see on my truck - which also has that crossmember... https://cimg1.ibsrv.net/gimg/www.for...dac97c7ff4.jpg |
Originally Posted by meangreen92
(Post 17798713)
Easy, just rotate the spring 180º, or thereabouts, in its seats.
What do you guys and gals recommend, steering ujoints or rag joint? My shaft lines up straight with the gearbox shaft.
