Ford Truck Enthusiasts Forums
-   1973 - 1979 F-100 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum38/)
-   -   New to the forum 74 f100 2wd swb. (https://www.ford-trucks.com/forums/1492505-new-to-the-forum-74-f100-2wd-swb.html)
PapaBearYuma 01-02-2018 02:23 PM
Originally Posted by MrQuick (Post 17696417)
sorry about that last post, I think I just figured out how to post pics from google photo.
well the whole aluminum gauge cluster thing didn't work out
https://cimg0.ibsrv.net/gimg/www.for...3f6c649f5f.png
The guy I had welding it for me got it to hot and ruined it. So I'm going another route
hopefully something like this.
https://cimg3.ibsrv.net/gimg/www.for...6b7604fedf.png
How hard is it going to be to get to those nuts that hold down the dash pad?
Iíve had the dash pad out of all the trucks. No big deal, but you need to remove the cluster and the glove box liner. Thereís more work room if you donít have AC, but even if you do, itís not that bad.
MrQuick 01-02-2018 04:18 PM
Thank you for the reply Papabear. I already have everything out, I was referring to installing the dash pad when all is finished and how much trouble it may be if I don't have a removable instrument cluster. The one in the picture above doesn't appear to be removable in and of itself.
MrQuick 01-02-2018 04:21 PM
On a totally different subject. Do any of you guys know what these are called and if they are available I don't know how to search for these?
https://cimg9.ibsrv.net/gimg/www.for...e0b8bebc57.png
PapaBearYuma 01-02-2018 08:51 PM
Hmmm...I can see where it might be a challenge to work behind the dash!
The pad has studs all the way across that are secured to the dash frame by nuts. It's gonna be a touch reach up from under the steering column.
The other "nuts" look like the plastic inserts for license plates. Maybe check that section at the auto part to see of they match up.
MrQuick 01-03-2018 06:10 AM
thank you, I'll check that today.
John R. Thomas 01-05-2018 02:17 PM
What happened to the a.c. vents? My wife insists on it or she refuses to ride in my F-150
in hot weather.
MrQuick 01-05-2018 05:50 PM
in hot weather.
HaHa this is not my truck, My wife as well has insisted on a.c. although I hope mine turns out as nice as this one.
72rtchallenger 01-05-2018 07:58 PM
Are these the headlight adjusting screws an inserts you need ? I am not sure but I think it might be what your looking for as a replacement
https://shop.broncograveyard.com/197...uctinfo/24852/
MrQuick 01-15-2018 05:00 PM
Thanks 72rtchallenger I do believe that is the correct part. I also believe they have a bolt kit that has these adjusters in the kit. Ill call tomorrow thanks again.:)
MrQuick 01-15-2018 05:06 PM
Just some updates, Still waiting on engine, among other things.
https://cimg8.ibsrv.net/gimg/www.for...434478d769.png
por15 applied.
https://cimg1.ibsrv.net/gimg/www.for...23400ffd58.png
https://cimg3.ibsrv.net/gimg/www.for...999184db27.png
MrQuick 01-15-2018 05:08 PM
https://cimg2.ibsrv.net/gimg/www.for...2dc2032267.png
E-STOPP mocked up.
MrQuick 01-15-2018 05:15 PM
https://cimg7.ibsrv.net/gimg/www.for...1140b7de71.png
finally got the cab set on and bolted down.<br/>
MrQuick 01-15-2018 05:17 PM
Here is a video of the E-STOPP in action.
MrQuick 01-15-2018 06:43 PM
72rtchallenger 01-15-2018 06:51 PM
looks good
